Commit e5834d8d authored by Alexis BITAILLOU's avatar Alexis BITAILLOU
[Nantes] ecotaxe init
parent c527255c
Pipeline #1185523 failed
# $REFERENCE_REPO/input/grid5000/sites/nantes/clusters/ecotaxe/ecotaxe.yaml
model: HPE DL385 G10 Plus v2
created_at: 2025-05-21 16:40:55.149032
kavlan: false
boot_type: uefi
queues:
- admin
nodes:
ecotaxe-[1-2]:
network_adapters:
eth1:
enabled: true
mountable: true
ecotaxe-[1-2]:
processor:
microarchitecture: Zen 3
clock_speed: 2750000000
software:
standard-environment: debian11-x64-std
management_tools:
bmc_vendor_tool: ipmitool
supported_job_types:
deploy: true
besteffort: true
max_walltime: 0
network_adapters:
eth0:
mounted: true
enabled: true
mountable: true
eth1:
mounted: false
enabled: true
mountable: true
bmc:
interface: Ethernet
rate: 1.0e+9
enabled: true
mounted: false
mountable: false
storage_devices:
pci-0000:03:00.0-scsi-0:0:0:0:
interface: SAS
nodeset: ecotaxe
metrics:
- name: prom_default_metrics
description: Default subset of metrics from Prometheus Node Exporter
period: 0
optional_period: 15000
source:
protocol: prometheus
port: 9100
id:
- node_boot_time_seconds
- node_cpu_scaling_frequency_hertz
- node_cpu_seconds_total
- node_filesystem_free_bytes
- node_filesystem_size_bytes
- node_load1
- node_load15
- node_load5
- node_memory_Buffers_bytes
- node_memory_Cached_bytes
- node_memory_MemAvailable_bytes
- node_memory_MemFree_bytes
- node_memory_MemTotal_bytes
- node_memory_Shmem_bytes
- node_memory_SwapFree_bytes
- node_memory_SwapTotal_bytes
- node_network_receive_bytes_total
- node_network_receive_packets_total
- node_network_transmit_bytes_total
- node_network_transmit_packets_total
- node_procs_blocked
- node_procs_running
- kwollect_custom
- name: prom_all_metrics
description: All metrics from Prometheus Node Exporter
period: 0
source:
port: 9100
# Generated by g5k-checks (g5k-checks -m api)
ecotaxe-1:
architecture:
cpu_core_numbering: round-robin
nb_cores: 20
nb_procs: 2
nb_threads: 40
platform_type: x86_64
bios:
release_date: 12/12/2023
vendor: Dell Inc.
version: 2.19.0
bmc_version: 2.86.86.86
chassis:
manufacturer: Dell Inc.
serial: 7WT8QK2
main_memory:
ram_size: 137438953472
memory_devices:
dimm_a1:
technology: dram
dimm_a2:
technology: dram
dimm_a3:
technology: dram
dimm_a4:
technology: dram
dimm_b1:
technology: dram
dimm_b2:
technology: dram
dimm_b3:
technology: dram
dimm_b4:
technology: dram
network_adapters:
bmc:
ip: 172.17.193.50
mac: 5c:ed:8c:3e:4a:be
management: true
eth0:
driver: ixgbe
firmware_version: 0x8000095c, 19.5.12
interface: Ethernet
ip: 172.16.193.50
mac: 00:e0:7c:c9:15:be
management: false
model: 82599ES 10-Gigabit SFI/SFP+ Network Connection
rate: 10000000000
sriov: true
sriov_totalvfs: 63
vendor: Intel
eth1:
driver: ixgbe
interface: Ethernet
mac: 24:6e:96:6a:d3:2a
management: false
rate: 10000000000
sriov: true
sriov_totalvfs: 63
vendor: Intel
operating_system:
cstate_driver: intel_idle
cstate_governor: menu
ht_enabled: true
pstate_driver: intel_cpufreq
pstate_governor: performance
turboboost_enabled: true
processor:
cache_l1d: 32768
cache_l1i: 32768
cache_l2: 262144
cache_l3: 26214400
ht_capable: true
instruction_set: x86-64
microcode: '0xb000040'
model: Intel Xeon
other_description: Intel(R) Xeon(R) CPU E5-2630L v4 @ 1.80GHz
vendor: Intel
version: E5-2630L v4
storage_devices:
by_id: "/dev/disk/by-id/wwn-0x50000397cc890081"
by_path: "/dev/disk/by-path/pci-0000:03:00.0-scsi-0:0:0:0"
firmware_version: AM07
model: PX04SMB040
storage: SSD
virtual: ivt
ecotaxe-2:
architecture:
nb_cores: 20
nb_procs: 2
nb_threads: 40
bios:
vendor: Dell Inc.
version: 2.19.0
chassis:
serial: 7WPCQK2
main_memory:
memory_devices:
dimm_a1:
technology: dram
dimm_a2:
technology: dram
dimm_a3:
technology: dram
dimm_a4:
technology: dram
dimm_b1:
technology: dram
dimm_b2:
technology: dram
dimm_b3:
technology: dram
dimm_b4:
technology: dram
network_adapters:
bmc:
ip: 172.17.193.51
mac: 5c:ed:8c:3e:4a:de
management: true
eth0:
driver: ixgbe
interface: Ethernet
ip: 172.16.193.51
mac: bc:0f:9a:d2:0a:a8
management: false
rate: 10000000000
sriov: true
sriov_totalvfs: 63
vendor: Intel
eth1:
driver: ixgbe
interface: Ethernet
mac: 24:6e:96:6a:d6:b2
management: false
rate: 10000000000
sriov: true
sriov_totalvfs: 63
vendor: Intel
eth2:
driver: igb
firmware_version: 1.67, 0x80000fab, 19.5.12
interface: Ethernet
mac: 24:6e:96:6a:d6:b4
management: false
model: I350 Gigabit Network Connection
sriov: false
sriov_totalvfs: 0
vendor: Intel
processor:
cache_l1d: 32768
cache_l1i: 32768
cache_l2: 262144
cache_l3: 26214400
ht_capable: true
model: Intel Xeon
vendor: Intel
storage_devices:
by_id: "/dev/disk/by-id/wwn-0x50000397cc890011"
model: PX04SMB040
storage: SSD
virtual: ivt
