GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
grid5000
reference-repository
de16113a
de16113a
JONGLEZ Baptiste
Merge branch 'general_fixes' into 'master'
Fix for issues preventing cluster bootstrap See merge request
!145
parents
9167c721
c32726a1
Pipeline
#182875
passed with stages
in 7 minutes and 19 seconds
3
input/grid5000/disks.yaml
de16113a
@@ -65,3 +65,5 @@ disk_vendor_model_mapping:
Micron
Micron
MTFDDAK480TDN
MTFDDAK480TDN
MTFDDAK960TDN
MTFDDAK960TDN
Unknown
unknown
lib/refrepo/input_loader.rb
de16113a
@@ -183,6 +183,7 @@ end
def
add_kavlan_ipv6s
h
def
add_kavlan_ipv6s
h
h
'sites'
each_pair
do
site_uid
hs
h
'sites'
each_pair
do
site_uid
hs
hs
'clusters'
each_pair
do
_cluster_uid
hc
hs
'clusters'
each_pair
do
_cluster_uid
hc
next
if
hc
'kavlan'
# skip clusters where kavlan is globally set to false (used for initial cluster installation)
hc
'nodes'
each_pair
do
node_uid
hn
hc
'nodes'
each_pair
do
node_uid
hn
kvl_adapters
hn
'network_adapters'
select
_k
v
v
'mountable'
v
'kavlan'
not
v
has_key?
'kavlan'
v
'interface'
'Ethernet'
kvl_adapters
hn
'network_adapters'
select
_k
v
v
'mountable'
v
'kavlan'
not
v
has_key?
'kavlan'
v
'interface'
'Ethernet'
if
kvl_adapters
length
if
kvl_adapters
length
@@ -222,6 +223,9 @@ def add_software(h)
h
'sites'
each_pair
do
site_uid
hs
h
'sites'
each_pair
do
site_uid
hs
hs
'clusters'
each_pair
do
cluster_uid
hc
hs
'clusters'
each_pair
do
cluster_uid
hc
hc
'nodes'
each_pair
do
node_uid
hn
hc
'nodes'
each_pair
do
node_uid
hn
if
not
hn
key?
'software'
hn
'software'
hn
'software'
'postinstall-version'
h
'software'
hn
'software'
h
'software'
hn
'software'
'forced-deployment-timestamp'
h
'software'
hn
'software'
h
'software'
lib/refrepo/valid/input/schemas/schema-node.yaml
de16113a
@@ -23,11 +23,13 @@ chassis:
exotic
optional_boolean
exotic
optional_boolean
gpu_devices
optional_hash
gpu_devices
optional_hash
kavlan
kavlan
<multi>
<optional_hash>
<multi>
ip_address
<multi>
<multi>
ip_address
kavlan6
kavlan6
<multi>
<optional_hash>
<multi>
ip_address
<multi>
<multi>
ip_address
main_memory
main_memory
ram_size
integer
ram_size
integer
pmem_size
optional_integer
pmem_size
optional_integer
