Commit d78dbd39 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[wiki/generators/status] remove reference to...
[wiki/generators/status] remove reference to https://intranet.grid5000.fr/net/Lille/ since it was removed
parent cc163461
1 merge request!908[wiki/generators/status] remove reference to...
Pipeline #1093559 passed
...@@ -102,10 +102,7 @@ class StatusGenerator < WikiGenerator ...@@ -102,10 +102,7 @@ class StatusGenerator < WikiGenerator
data += "[http://pasillo.renater.fr/weathermap/weathermap_g5k.html Grid'5000 Weathermap] (courtesy of Renater)\n" data += "[http://pasillo.renater.fr/weathermap/weathermap_g5k.html Grid'5000 Weathermap] (courtesy of Renater)\n"
data += MW::LINE_FEED data += MW::LINE_FEED
data += "Shows the actual state of the opticals links between the Grid'5000 10Gb-ready sites. A link painted in black on the weathermap means that you won't be able to access this site nodes from the Grid'5000 internal network.\n" data += "Shows the actual state of the opticals links between the Grid'5000 10Gb-ready sites. A link painted in black on the weathermap means that you won't be able to access this site nodes from the Grid'5000 internal network.\n"
data += "== Sites network traffic ==\n"
data + "A dashboard combining links and real-time data is available on the [https://intranet.grid5000.fr/net/Lille/ Grid'5000 Backbone Network Monitoring] page.\n"
end end
def generate_node_monitoring def generate_node_monitoring
