Commit cf45ff5f authored by PARISOT Clement's avatar PARISOT Clement
[grenoble] network - Fix port-channel40 name on gw
parent 421b49e5
1 merge request!1013[grenoble] network - Fix port-channel40 name on gw
Pipeline #1115300 passed
...@@ -343,13 +343,13 @@ ...@@ -343,13 +343,13 @@
"kind": "channel", "kind": "channel",
"rate": 10000000000, "rate": 10000000000,
"snmp_name": "ethernet1/1/49", "snmp_name": "ethernet1/1/49:1",
"uid": "port-channel40" "uid": "port-channel40"
"snmp_name": "ethernet1/1/50", "snmp_name": "ethernet1/1/50:1",
...@@ -172,12 +172,12 @@ gw: ...@@ -172,12 +172,12 @@ gw:
uid: port-channel40 uid: port-channel40
kind: channel kind: channel
rate: 10_000_000_000 rate: 10_000_000_000
snmp_pattern: "ethernet1/1/%PORT%" snmp_pattern: "ethernet1/1/%PORT%:1"
50: 50:
67: 67:
uid: port-channel50 uid: port-channel50
