GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
cc6788bd
cc6788bd
5 years ago
IMBERT Matthieu
Downloads
Patches
[kavlan] prefix unused variables with _ (rubocop)
fa43859f
Branches containing commit
Tags containing commit
lib/refrepo/input_loader.rb
+2
-3
2 additions, 3 deletions
2 additions
3 deletions
2
3
cc6788bd
@@ -143,8 +143,7 @@ def add_kavlan_ipv6s(h)
h
'sites'
each_pair
do
site_uid
hs
hs
'clusters'
each_pair
do
cluster_uid
hc
hc
'nodes'
each_pair
do
node_uid
hn
node_id
node_uid
split
to_i
kvl_adapters
hn
'network_adapters'
select
k
v
v
'mountable'
v
'kavlan'
not
v
has_key?
'kavlan'
v
'interface'
'Ethernet'
kvl_adapters
hn
'network_adapters'
select
_k
v
v
'mountable'
v
'kavlan'
not
v
has_key?
'kavlan'
v
'interface'
'Ethernet'
if
kvl_adapters
length
if
kvl_adapters
length
hn
'kavlan'
length
raise
node_uid
: inconsistency: num kvl_adapters =
kvl_adapters
length
, num kavlan entries =
hn
'kavlan'
length
@@ -154,7 +153,7 @@ def add_kavlan_ipv6s(h)
ip4
kvl_adapters
values
'ip'
hn
'kavlan6'
kvl_adapters
each_with_index
do
iface
nah
idx
kvl_adapters
each_with_index
do
iface
_
nah
idx
hn
'kavlan6'
iface
hn
'kavlan'
iface
each_key
do
kvl
kvl_id
kvl
split
to_i
This diff is collapsed.
Loading
Save comment
