Commit be72fb35 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[dev] cleanup
parent d0790c8b
#!/usr/bin/env ruby
require 'refrepo/gen/wiki/wiki_generator' require 'refrepo/gen/wiki/wiki_generator'
require 'refrepo/gen/wiki/mw_utils' require 'refrepo/gen/wiki/mw_utils'
require 'refrepo/gen/wiki/generators/cpu_parameters' require 'refrepo/gen/wiki/generators/cpu_parameters'
class CPUParametersGenerator < WikiGenerator class CPUParametersGenerator < WikiGenerator
# coding: utf-8 # coding: utf-8
$LOAD_PATH.unshift(File.expand_path(File.join(File.dirname(__FILE__), 'lib')))
class DiskReservationGenerator < WikiGenerator class DiskReservationGenerator < WikiGenerator
require 'refrepo/gen/wiki/generators/site_hardware' require 'refrepo/gen/wiki/generators/site_hardware'
class G5KHardwareGenerator < WikiGenerator class G5KHardwareGenerator < WikiGenerator
require 'refrepo/gen/oar-properties' require 'refrepo/gen/oar-properties'
class SiteHardwareGenerator < WikiGenerator class SiteHardwareGenerator < WikiGenerator
require 'refrepo/valid/network' require 'refrepo/valid/network'
# This class generates the network description of each site, in .dot # This class generates the network description of each site, in .dot
