- Downloads
[spec] update the oar_properties2 test expected outputs after adding the chassis property
cc551f46
- spec/output/graffiti_empty_diff_stdout.txt 14 additions, 1 deletionspec/output/graffiti_empty_diff_stdout.txt
- spec/output/graffiti_empty_print_stdout.txt 14 additions, 13 deletionsspec/output/graffiti_empty_print_stdout.txt
- spec/output/graphite_empty_diff_stdout.txt 5 additions, 1 deletionspec/output/graphite_empty_diff_stdout.txt
- spec/output/graphite_empty_print_stdout.txt 5 additions, 4 deletionsspec/output/graphite_empty_print_stdout.txt
- spec/output/grimoire_empty_diff_stdout.txt 9 additions, 1 deletionspec/output/grimoire_empty_diff_stdout.txt
- spec/output/grimoire_empty_print_stdout.txt 9 additions, 8 deletionsspec/output/grimoire_empty_print_stdout.txt
- spec/output/grue_empty_diff_stdout.txt 6 additions, 1 deletionspec/output/grue_empty_diff_stdout.txt
- spec/output/grue_empty_print_stdout.txt 6 additions, 5 deletionsspec/output/grue_empty_print_stdout.txt
- spec/output/grue_nogpus_diff_stdout.txt 34 additions, 5 deletionsspec/output/grue_nogpus_diff_stdout.txt
- spec/output/grue_nogpus_print_stdout.txt 6 additions, 5 deletionsspec/output/grue_nogpus_print_stdout.txt
- spec/output/yeti_empty_diff_stdout.txt 5 additions, 1 deletionspec/output/yeti_empty_diff_stdout.txt
- spec/output/yeti_empty_print_stdout.txt 5 additions, 4 deletionsspec/output/yeti_empty_print_stdout.txt
Loading
