GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
grid5000
b62b76c9
b62b76c9
2 months ago
SECK Jean-Camille
Downloads
Patches
[louvain][kwollect][spirou] add metrics for spirou
e9d3e35c
1 merge request
!1136
Spirou kwollect
input/grid5000/sites/louvain/clusters/spirou/spirou_metrics.yaml
+42
42 additions, 0 deletions
...rid5000/sites/louvain/clusters/spirou/spirou_metrics.yaml
42 additions
42
b62b76c9
metrics
name
prom_default_metrics
description
Default subset of metrics from Prometheus Node Exporter
period
optional_period
15000
source
protocol
prometheus
port
9100
id
node_boot_time_seconds
node_cpu_scaling_frequency_hertz
node_cpu_seconds_total
node_filesystem_free_bytes
node_filesystem_size_bytes
node_load1
node_load15
node_load5
node_memory_Buffers_bytes
node_memory_Cached_bytes
node_memory_MemAvailable_bytes
node_memory_MemFree_bytes
node_memory_MemTotal_bytes
node_memory_Shmem_bytes
node_memory_SwapFree_bytes
node_memory_SwapTotal_bytes
node_network_receive_bytes_total
node_network_receive_packets_total
node_network_transmit_bytes_total
node_network_transmit_packets_total
node_procs_blocked
node_procs_running
kwollect_custom
name
prom_all_metrics
description
All metrics from Prometheus Node Exporter
period
optional_period
15000
source
protocol
prometheus
port
9100
This diff is collapsed.
Loading
Save comment
