Commit b54e16b6 authored by BERARD Benjamin's avatar BERARD Benjamin
[nancy][graphique] Update mac address to graphique-2
parent a26b8de1
Pipeline #118775 failed
...@@ -75,7 +75,7 @@ ...@@ -75,7 +75,7 @@
"ip": "172.16.67.2", "ip": "172.16.67.2",
"ip6": "2001:660:4406:500:4::2", "ip6": "2001:660:4406:500:4::2",
"kavlan": true, "kavlan": true,
"mac": "44:a8:42:07:6a:c8", "mac": "d0:94:66:63:62:32",
"management": false, "management": false,
"model": "NetXtreme II BCM57800 1/10 Gigabit Ethernet", "model": "NetXtreme II BCM57800 1/10 Gigabit Ethernet",
"mountable": true, "mountable": true,
...@@ -95,7 +95,7 @@ ...@@ -95,7 +95,7 @@
"firmware_version": "FFV7.10.18 bc 7.10.11", "firmware_version": "FFV7.10.18 bc 7.10.11",
"interface": "Ethernet", "interface": "Ethernet",
"kavlan": false, "kavlan": false,
"mac": "44:a8:42:07:6a:ca", "mac": "d0:94:66:63:62:34",
"mountable": false, "mountable": false,
...@@ -111,7 +111,7 @@ ...@@ -111,7 +111,7 @@
"mac": "44:a8:42:07:6a:cc", "mac": "d0:94:66:63:62:36",
...@@ -127,7 +127,7 @@ ...@@ -127,7 +127,7 @@
"mac": "44:a8:42:07:6a:ce", "mac": "d0:94:66:63:62:38",
...@@ -45,7 +45,7 @@ graphique-2: ...@@ -45,7 +45,7 @@ graphique-2:
firmware_version: FFV7.10.18 bc 7.10.11 firmware_version: FFV7.10.18 bc 7.10.11
interface: Ethernet interface: Ethernet
ip: 172.16.67.2 ip: 172.16.67.2
mac: 44:a8:42:07:6a:c8 mac: d0:94:66:63:62:32
management: false management: false
model: NetXtreme II BCM57800 1/10 Gigabit Ethernet model: NetXtreme II BCM57800 1/10 Gigabit Ethernet
name: eno1 name: eno1
...@@ -55,7 +55,7 @@ graphique-2: ...@@ -55,7 +55,7 @@ graphique-2:
driver: bnx2x driver: bnx2x
mac: 44:a8:42:07:6a:ca mac: D0:94:66:63:62:34
name: eno2 name: eno2
...@@ -64,7 +64,7 @@ graphique-2: ...@@ -64,7 +64,7 @@ graphique-2:
mac: 44:a8:42:07:6a:cc mac: D0:94:66:63:62:36
name: eno3 name: eno3
...@@ -73,7 +73,7 @@ graphique-2: ...@@ -73,7 +73,7 @@ graphique-2:
mac: 44:a8:42:07:6a:ce mac: D0:94:66:63:62:38
name: eno4 name: eno4
