Commit b2d8530a authored by POUILLOUX Laurent's avatar POUILLOUX Laurent
[puppet][clusters] update values from hiera with value from refrepo
parent 22ccf808
1 merge request!642Warranty refactoring
require 'refrepo/data_loader' require 'refrepo/data_loader'
def generate_puppet_clusters(options) def generate_puppet_clusters(options)
if not options[:conf_dir] if not options[:conf_dir]
options[:conf_dir] = "#{options[:output_dir]}/platforms/production/hieradata/" options[:conf_dir] = "#{options[:output_dir]}/platforms/production/hieradata/"
end end
# Loading current data from hiera
if options[:sites] != G5K_SITES hiera = YAML.load_file("#{options[:conf_dir]}clusters.yaml")['grid5000::clusters']
raise "SITE options is not valid as clusters.yaml contains all sites"
data = load_data_hierarchy
data.delete_if { |key| key != 'sites' }
yaml_data = {} # Updating data from refrepo
refrepo = load_data_hierarchy
refrepo.delete_if { |key| key != 'sites' }
data['sites'].sort.each do |s_uid, s_hash| refrepo['sites'].select{ |k, _v| options[:sites].include? k}.sort.each do |s_uid, s_hash|
yaml_data[s_uid] = {} if ! hiera.key? s_uid
puts "Add #{s_uid}"
hiera[s_uid] = {}
s_hash['clusters'].sort_by{|c_uid, _c_hash| [c_uid[/(\D+)/, 1], c_uid[/(\d+)/, 1].to_i]}.each do |c_uid, c_hash| s_hash['clusters'].sort_by{|c_uid, _c_hash| [c_uid[/(\D+)/, 1], c_uid[/(\d+)/, 1].to_i]}.each do |c_uid, c_hash|
if ! hiera[s_uid].key? c_uid
puts " Add #{s_uid}"
hiera[s_uid][c_uid] = {}
_, f_node = c_hash["nodes"].first _, f_node = c_hash["nodes"].first
queue = f_node['supported_job_types']['queues'].sort.reverse.first queue = f_node['supported_job_types']['queues'].select{|q| q != 'admin'}[0]
disk_reservation = f_node['storage_devices'].filter{|d| d.key?('reservation')}.length > 0 disk_reservation = f_node['storage_devices'].filter{|d| d.key?('reservation')}.length > 0
gpu = f_node.key?('gpu_devices') gpu = f_node.key?('gpu_devices')
if ! f_node.key?('chassis') if ! f_node.key?('chassis')
puts "no chassis field for #{f_node['uid']}, setting warranty to false" puts "no chassis field for #{f_node['uid']}, has g5k-checks data been imported ?"
warrantied = false warrantied = false
else else
warrantied = f_node['chassis'].key?('warranty_end') ? DateTime.parse(f_node['chassis']['warranty_end']) > DateTime.now : false warrantied = f_node['chassis'].key?('warranty_end') ? DateTime.parse(f_node['chassis']['warranty_end']) > DateTime.now : false
end end
c_data = {"queue" => queue,
yaml_data[s_uid][c_uid] = {"queue" => queue, "disk_reservation" => disk_reservation,
"disk_reservation" => disk_reservation, "gpu" => gpu,
"gpu" => gpu, "warrantied" => warrantied}
"warrantied" => warrantied} if hiera[s_uid][c_uid] != c_data
diff = hiera[s_uid][c_uid].dup.delete_if { |k, v| c_data[k] == v }.merge!(c_data.dup.delete_if { |k, _v| hiera[s_uid][c_uid].has_key?(k) })
puts "#{s_uid}-#{c_uid} Changes detected #{diff}"
hiera[s_uid][c_uid] = c_data
end end
end end
outfile = File.open("#{options[:conf_dir]}clusters.yaml", "w") outfile = File.open("#{options[:conf_dir]}clusters.yaml", "w")
outfile.write({'grid5000::clusters' => yaml_data}.to_yaml) outfile.write({'grid5000::clusters' => hiera}.to_yaml)
end end
\ No newline at end of file
