Commit a8f15361 authored by Sebastien Badia's avatar Sebastien Badia
[nancy] Add Graphene cluster prod
parent 74638098
......@@ -8,10 +8,11 @@ site :nancy do |site_uid|
sys_admin_contact "nancy-staff@lists.grid5000.fr"
security_contact "nancy-staff@lists.grid5000.fr"
user_support_contact "nancy-staff@lists.grid5000.fr"
( %w{sid-x64-base-1.0 sid-x64-base-1.1 sid-x64-nfs-1.0 sid-x64-nfs-1.1 sid-x64-big-1.1} +
%w{etch-x64-base-1.0 etch-x64-base-1.1 etch-x64-nfs-1.0 etch-x64-nfs-1.1 etch-x64-big-1.0 etch-x64-big-1.1 etch-x64-xen-1.0 etch-x64-base-2.0 etch-x64-nfs-2.0 etch-x64-big-2.0} +
%w{lenny-x64-base-0.9 lenny-x64-nfs-0.9 lenny-x64-big-0.9 lenny-x64-base-1.0 lenny-x64-nfs-1.0 lenny-x64-big-1.0 lenny-x64-xen-1.0 lenny-x64-base-2.0 lenny-x64-nfs-2.0 lenny-x64-big-2.0} ).each{|env_uid| environment env_uid, :refer_to => "grid5000/environments/#{env_uid}"}
compilation_server false
cluster :griffon do |cluster_uid|
model "Carri System CS-5393B"
created_at Time.parse("2009-04-10").httpdate
......@@ -20,7 +21,7 @@ site :nancy do |site_uid|
serial lookup('nancy', node_uid, 'serial')
supported_job_types({:deploy => true, :besteffort => true, :virtual => "ivt"})
architecture({
:smp_size => 2,
:smp_size => 2,
:smt_size => 8,
:platform_type => "x86_64"
......@@ -60,9 +61,10 @@ site :nancy do |site_uid|
:management => false,
:switch => lookup('nancy', "#{node_uid}", 'switch_eth0'),
:mac => lookup('nancy', "#{node_uid}", 'mac_eth0'),
:switch_port => lookup('nancy', "#{node_uid}", 'switch_pos_eth0'),
:network_address => "#{node_uid}.#{site_uid}.grid5000.fr",
:ip => dns_lookup("#{node_uid}.#{site_uid}.grid5000.fr"),
#:ip => dns_lookup("#{node_uid}.#{site_uid}.grid5000.fr"),
:ip => lookup('nancyipgrif', node_uid, 'ip_eth0'),
:driver => "e1000e", :vendor => "intel", :version => "80003ES2LAN"
......@@ -117,5 +119,151 @@ site :nancy do |site_uid|
end # cluster griffon
cluster :graphene do |cluster_uid|
model "Carri System 5393"
created_at Time.parse("2011-01-01").httpdate
144.times do |i|
node "#{cluster_uid}-#{i+1}" do |node_uid|
architecture({
:smp_size => 1,
:smt_size => 4,
processor({
:vendor => "Intel",
:model => "Intel Xeon",
:version => "X3440",
:clock_speed => 2.53.G,
:instruction_set => "",
:other_description => "",
:cache_l1 => nil,
:cache_l1i => nil,
:cache_l1d => nil,
:cache_l2 => 8.MiB
main_memory({
:ram_size => 16.GiB,
:virtual_size => nil
operating_system({
:name => "Debian",
:release => "5.0",
:version => nil,
:kernel => "2.6.26"
storage_devices [{
:interface => 'SATA II',
:size => 320.GB,
:driver => "ahci",
:device => "sda",
:model => lookup('nancy', node_uid, 'disk_model'),
:rev => lookup('nancy', node_uid, 'disk_rev')
network_adapters [{
:interface => 'Ethernet',
:rate => 1.G,
:device => "eth0",
:enabled => true,
:mounted => true,
:mountable => true,
:ip => lookup('nancy', node_uid, 'ip_eth0'),
:vendor => "intel",
:version => "82574L"
:rate => 1.G,
#:device => "eth1",
:enabled => false,
#:mounted => false,
:mac => lookup('nancy', "#{node_uid}", 'mac_eth1'),
#:management => false,
#:driver => "e1000e",
:vendor => "intel",
:rate => 1.G,
#:device => "eth2",
:enabled => false,
#:mounted => false,
:mac => lookup('nancy', "#{node_uid}", 'mac_eth2'),
:vendor => "intel",
:interface => 'InfiniBand',
:rate => 20.G,
:device => "ib0",
:enabled => true,
:mounted => true,
:mountable => true,
:ip => lookup('nancy', "#{node_uid}", 'ip_ib'),
:network_address => "#{node_uid}-ib0.#{site_uid}.grid5000.fr",
:switch => "sgrapheneib",
#:ib_switch_card => lookup('nancy',"#{node_uid}", 'switch_ib_card'),
#:ib_switch_card_pos => lookup('nancy',"#{node_uid}", 'switch_ib_card_pos'),
:driver => "mlx4_core",
:vendor => "Mellanox",
:version => "MT26418",
:mac => lookup('nancy', node_uid, 'guidib0')
:rate => 20.G,
:enabled => false,
#:device => "ib1",
#:driver => "mlx4_core",
#:mountable => false,
#:mounted => false,
:mac => lookup('nancy', node_uid, 'guidib1')
:rate => 100.M,
:enabled => true,
:mounted => false,
:management => true,
:vendor => "Tyan",
:version => "AST2050",
:device => "bmc",
:ip => lookup('nancy', "#{node_uid}", 'ip_mgt'),
:network_address => "#{node_uid}-bmc.#{site_uid}.grid5000.fr",
:switch => lookup('nancy', "#{node_uid}", 'switch_ipmi'),
:switch_port => lookup('nancy', "#{node_uid}", 'switch_ipmi_pos'),
:mac => lookup('nancy', "#{node_uid}", 'mac_mgt'),
pdu({
:vendor => "American Power Convertion",
:pdu => lookup('nancy', "#{node_uid}", 'pdu'),
:pdu_port => lookup('nancy', "#{node_uid}", 'pdu_pos')
bios({
:version => lookup('nancy', node_uid, 'bios_ver'),
:vendor => "American Megatrends Inc.",
:release_date => lookup('nancy', node_uid, 'bios_release')
end # cluster graphene
This diff is collapsed.
