Commit a8ab0a59 authored by LOUP David's avatar LOUP David
[gen:puppet:kavlan] Add support for uefi / arm64 pxe boot on kavlan DHCP
parent aa28148f
Pipeline #143560 passed
......@@ -10,6 +10,43 @@ option pxelinux.pathprefix code 210 = text;
option pxelinux.reboottime code 211 = unsigned integer 32;
option vendorinfo code 43 = string;
# define Option for the PXE class
option space PXE;
option PXE.mtftp-ip code 1 = ip-address;
option PXE.mtftp-cport code 2 = unsigned integer 16;
option PXE.mtftp-sport code 3 = unsigned integer 16;
option PXE.mtftp-tmout code 4 = unsigned integer 8;
option PXE.mtftp-delay code 5 = unsigned integer 8;
option PXE.discovery-control code 6 = unsigned integer 8;
option PXE.discovery-mcast-addr code 7 = ip-address;
option arch code 93 = unsigned integer 16;
# create the Class PXE
class "PXE" {
# if the vendor-class-identifier is set to PXEClient in the client dhcp request
match if substring(option vendor-class-identifier, 0, 9) = "PXEClient";
# filename define the file retrieve by the client, there pxelinux.0
# our tftp is chrooted so is just the path to the file
# If you prefer use grub, use pxegrub compiled for your ethernet card.
if option arch = 00:07 {
filename "/grub/x86_64-efi/core.efi";
} else if option arch = 00:09 {
} else if option arch = 00:0b {
filename "/grub/arm64-efi/core.efi";
} else {
filename "/pxelinux.0";
# Set the vendor-class-identifier field to PXEClient in dhcp answer
# if this field is not set the pxe client will ignore the answer !
option vendor-class-identifier "PXEClient";
vendor-option-space PXE;
option PXE.mtftp-ip 0.0.0.0;
kavlan = refapi['sites'][site_uid]['kavlans'][kavlan_id.to_s] # TODO fix needed conversion
kavlan_ip = IPAddress::IPv4::new(kavlan['network'])
......@@ -23,7 +60,6 @@ subnet <%= kavlan_ip.network %> netmask <%= kavlan_ip.netmask %> {
option routers <%= kavlan['gateway'] %>;
option subnet-mask <%= kavlan_ip.netmask %>;
option broadcast-address <%= kavlan_ip.broadcast %>;
filename "pxelinux.0";
next-server <%= "kadeploy.#{site_uid}.grid5000.fr" %>;
