GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
a7da5c0a
a7da5c0a
8 years ago
Jérémie Gaidamour
Downloads
Patches
[dev] Turned an error message to a warning
fad53bfa
Branches containing commit
generators/oar-properties/oar-properties.rb
+1
-1
1 addition, 1 deletion
1 addition
1 deletion
a7da5c0a
@@ -266,7 +266,7 @@ if options[:diff]
properties_keys
"diff"
k
v_ref
unless
v_oar
properties_keys
"diff"
k
v_ref
unless
v_oar
if
v_oar
v_oar
v_ref
v_ref
NilClass
v_oar
NilClass
if
v_oar
v_oar
v_ref
v_ref
NilClass
v_oar
NilClass
# Detect inconsistency between the type (String/Fixnum) of properties generated by this script and the existing values on the server.
raise
"Error: the OAR property '
k
' is a '
v_oar
' on the server and this script uses '
v_ref
' for this property."
puts
k
' is a '
v_oar
v_ref
This diff is collapsed.
Loading
Save comment
