GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
9f167f3b
9f167f3b
9 years ago
Jérémie Gaidamour
Downloads
Patches
[dev] doc
03c1993d
Branches containing commit
generators/README.md
+1
-1
1 addition, 1 deletion
1 addition
1 deletion
9f167f3b
@@ -151,7 +151,7 @@ You have to set the 'reference_repo' environment variable so that the generators
Usage example:
Usage example:
$ (cd /tmp; git clone ssh://g5kadmin@git.grid5000.fr/srv/git/repos/
puppet-repo
) # or use your existing local copy of the repository
reference-repository.git
$ export reference_repo=/tmp/reference-repo
$ cd puppet-repo/modules/
<module_name>
/generators/
<module_name>
/generators/
$ rake # run the generator for
<module_name>
<module_name>
This diff is collapsed.
Loading
Save comment
