Commit 91827536 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[dev] Add text description of nodes at the cluster level (context: bug 11372)
I did not include the nodes count in the description, but used a
separate field.
The way the description is generated is copy/pasted from abamotd. I
propose to start with that, change consumers such as abamotd to use it,
and then improve if needed.
parent 9484286d
Loading
Checking pipeline status
with 40 additions and 0 deletions
Loading
