Commit 8e7c7d57 authored by RINGOT Patrice's avatar RINGOT Patrice
[nancy] sgrappe and sgruss are now attached to gw-next
parent 0c37e898
1 merge request!742[nancy] sgrappe and sgruss are now attached to gw-next
Pipeline #1006122 passed
...@@ -196,8 +196,16 @@ ...@@ -196,8 +196,16 @@
"uid": "sgros1" "uid": "sgros1"
"kind": "switch",
"rate": 40000000000,
"snmp_name": "1/1/50",
"uid": "sgruss"
"kind": "switch",
"snmp_name": "1/1/51",
"uid": "sgrappe"
...@@ -10,18 +10,6 @@ ...@@ -10,18 +10,6 @@
"port": "port-channel1", "port": "port-channel1",
"rate": 80000000000, "rate": 80000000000,
"uid": "sgros2" "uid": "sgros2"
"port-channel4": {
"kind": "switch",
"uid": "sgrappe"
"port-channel5": {
"kind": "switch",
"uid": "sgruss"
"ip": "172.16.79.254", "ip": "172.16.79.254",
...@@ -151,252 +139,12 @@ ...@@ -151,252 +139,12 @@
"snmp_pattern": "Ethernet%LINECARD%/%PORT%" "snmp_pattern": "Ethernet%LINECARD%/%PORT%"
"backplane_bps": 1280000000000,
"kavlan_pattern": "Ethernet%LINECARD%/%PORT%",
"kind": "node",
"model": "N9K-X9464PX",
"ports": [
"kind": "channel",
"snmp_name": "Ethernet2/49",
"uid": "port-channel5"
"kind": "channel",
"snmp_name": "Ethernet2/50",
"rate": 10000000000,
"kind": "node",
"ports": [
"kind": "channel",
"snmp_name": "Ethernet5/51",
"uid": "port-channel4"
"kind": "channel",
"snmp_name": "Ethernet5/52",
"backplane_bps": 1280000000000, "backplane_bps": 1280000000000,
"backplane_bps": 2160000000000, "backplane_bps": 2160000000000,
"channels": {
"port-channel1": {
"kind": "router",
"port": "port-channel4",
"uid": "gw"
"ip": "172.17.79.205", "ip": "172.17.79.205",
"kind": "switch", "kind": "switch",
"linecards": [ "linecards": [
...@@ -132,16 +124,10 @@ ...@@ -132,16 +124,10 @@
"kind": "channel", "kind": "switch",
"rate": 40000000000, "rate": 40000000000,
"snmp_name": "ethernet1/1/25:1", "snmp_name": "ethernet1/1/25:1",
"uid": "port-channel1" "uid": "gw-next"
"kind": "channel",
"snmp_name": "ethernet1/1/26:1",
"rate": 25000000000, "rate": 25000000000,
"channels": {
"port-channel1": {
"kind": "router",
"port": "port-channel5",
"uid": "gw"
"ip": "172.17.79.212", "ip": "172.17.79.212",
...@@ -100,16 +92,10 @@ ...@@ -100,16 +92,10 @@
"kind": "channel",
...@@ -142,39 +142,6 @@ gw: ...@@ -142,39 +142,6 @@ gw:
48: 48:
uid: renater-nancy uid: renater-nancy
kind: backbone kind: backbone
2:
snmp_pattern: "Ethernet%LINECARD%/%PORT%"
kavlan_pattern: "Ethernet%LINECARD%/%PORT%"
backplane_bps: 1280000000000
model: N9K-X9464PX
kind: node
rate: 10000000000
ports:
49:
uid: port-channel5
kind: channel
rate: 40_000_000_000
50:
uid: port-channel5
kind: channel
5:
model: N9K-X9464PX
kind: node
rate: 10000000000
ports:
51:
uid: port-channel4
kind: channel
52:
uid: port-channel4
kind: channel
6: 6:
snmp_pattern: "Ethernet%LINECARD%/%PORT%" snmp_pattern: "Ethernet%LINECARD%/%PORT%"
kavlan_pattern: "Ethernet%LINECARD%/%PORT%" kavlan_pattern: "Ethernet%LINECARD%/%PORT%"
...@@ -191,7 +158,6 @@ gw: ...@@ -191,7 +158,6 @@ gw:
uid: port-channel3 uid: port-channel3
kind: channel kind: channel
rate: 40_000_000_000 rate: 40_000_000_000
7: 7:
...@@ -238,13 +204,3 @@ gw: ...@@ -238,13 +204,3 @@ gw:
uid: sgros2 uid: sgros2
kind: switch kind: switch
rate: 80_000_000_000 rate: 80_000_000_000
port-channel4:
port: port-channel1
uid: sgrappe
kind: switch
port-channel5:
port: port-channel1
uid: sgruss
kind: switch
...@@ -109,6 +109,14 @@ gw-next: ...@@ -109,6 +109,14 @@ gw-next:
uid: sgros1 uid: sgros1
50:
uid: sgruss
kind: switch
51:
uid: sgrappe
kind: switch
53: 53:
uid: sgrvingt uid: sgrvingt
...@@ -97,18 +97,7 @@ sgrappe: ...@@ -97,18 +97,7 @@ sgrappe:
16: 16:
uid: grappe-16 uid: grappe-16
25: 25:
snmp_pattern: "ethernet1/%LINECARD%/%PORT%:1" snmp_pattern: "ethernet1/%LINECARD%/%PORT%:1"
rate: 40_000_000_000 uid: gw-next
uid: port-channel1 rate: 40_000_000_000
kind: channel kind: switch
26:
uid: port-channel1
kind: channel
channels:
port-channel1:
port: port-channel4
uid: gw
kind: router
...@@ -81,18 +81,7 @@ sgruss: ...@@ -81,18 +81,7 @@ sgruss:
18: 18:
uid: grouille-2-eth2 uid: grouille-2-eth2
25: 25:
26:
uid: port-channel1
kind: channel
channels:
port-channel1:
port: port-channel5
uid: gw
kind: router
