- Downloads
[spec] fix the oar_properties spec test after adding the chassis property
b9fc8e9e
- spec/oar_properties_spec.rb 20 additions, 11 deletionsspec/oar_properties_spec.rb
- spec/stub_oar_properties/dump_oar_api_configured_server.json 32 additions, 0 deletionsspec/stub_oar_properties/dump_oar_api_configured_server.json
- spec/stub_oar_properties/dump_oar_api_configured_server_missing_property.json 31 additions, 0 deletions...ties/dump_oar_api_configured_server_missing_property.json
- spec/stub_oar_properties/dump_oar_api_configured_server_quirk_cluster.json 38 additions, 0 deletions...perties/dump_oar_api_configured_server_quirk_cluster.json
- spec/stub_oar_properties/dump_oar_api_configured_server_with_disk.json 37 additions, 0 deletions..._properties/dump_oar_api_configured_server_with_disk.json
- spec/stub_oar_properties/dump_oar_api_configured_server_without_gpu.json 38 additions, 0 deletions...roperties/dump_oar_api_configured_server_without_gpu.json
Loading
