Commit 843f2737 authored by MIRTAIN Laurent's avatar MIRTAIN Laurent
Merge branch 'sophia_add_switch_sw_4' into 'master'
[sophia][network] add sw-4
See merge request !1286
parents fd72b5cc d1259644
1 merge request!1286[sophia][network] add sw-4
Pipeline #1181979 passed with warnings
Pipeline: Resources Explorer
#1181982
    ...@@ -203,6 +203,10 @@ ...@@ -203,6 +203,10 @@
    "uid": "gwol-south" "uid": "gwol-south"
    "kind": "switch",
    "rate": 10000000000,
    "snmp_name": "1/1/38",
    "uid": "sw-4"
    "backplane_bps": 1760000000000,
    "ip": "172.17.143.244",
    "kind": "switch",
    "linecards": [
    "kavlan_pattern": "%PORT%",
    "kind": "node",
    "ports": [
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/1",
    "uid": "mercantour3-3"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/2",
    "uid": "mercantour3-4"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/3",
    "uid": "mercantour3-7"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/4",
    "uid": "mercantour3-8"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/5",
    "uid": "mercantour3-11"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/6",
    "uid": "mercantour3-12"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/7",
    "uid": "mercantour3-15"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/8",
    "uid": "mercantour3-16"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/25",
    "uid": "mercantour3-1"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/26",
    "uid": "mercantour3-2"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/27",
    "uid": "mercantour3-5"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/28",
    "uid": "mercantour3-6"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/29",
    "uid": "mercantour3-9"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/30",
    "uid": "mercantour3-10"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/31",
    "uid": "mercantour3-13"
    "kind": "node",
    "port": "eth0",
    "snmp_name": "Gigabitethernet 1/0/32",
    "uid": "mercantour3-14"
    "rate": 1000000000,
    "snmp_pattern": "Gigabitethernet 1/%LINECARD%/%PORT%"
    "kind": "node",
    "ports": [
    "kind": "router",
    "snmp_name": "TenGigabitEthernet 1/0/1",
    "uid": "gw"
    "snmp_pattern": "TenGigabitEthernet %LINECARD%/0/%PORT%"
    "managed_by_us": true,
    "metrics": [
    "description": "Input byte counter for the network device port",
    "name": "network_ifacein_bytes_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.31.1.1.1.6.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Output byte counter for the network device port",
    "name": "network_ifaceout_bytes_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.31.1.1.1.10.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Input packet counter for the network device port",
    "name": "network_ifacein_packets_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.11.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Output packet counter for the network device port",
    "name": "network_ifaceout_packets_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.17.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Input counter of discarded packets for the network device port",
    "name": "network_ifacein_packets_discard_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.13.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Output counter of discarded packets for the network device port",
    "name": "network_ifaceout_packets_discard_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.19.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Input counter of packet errors for the network device port",
    "name": "network_ifacein_packets_error_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.14.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "description": "Output counter of packet errors for the network device port",
    "name": "network_ifaceout_packets_error_total",
    "period": 15000,
    "source": {
    "id": "1.3.6.1.2.1.2.2.1.20.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}",
    "protocol": "snmp"
    "model": "Dell PowerSwitch N1548",
    "serial": "BSWVNK2",
    "site": "sophia",
    "snmp_community": "public",
    "type": "network_equipment",
    "uid": "sw-4",
    "warranty": "2024-04-21"
    \ No newline at end of file
    ...@@ -114,9 +114,6 @@ gw: ...@@ -114,9 +114,6 @@ gw:
    16: 16:
    uid: lag7 uid: lag7
    kind: channel kind: channel
    37:
    uid: gwol-south
    kind: server
    31: 31:
    uid: musa-1 uid: musa-1
    32: 32:
    ...@@ -129,6 +126,13 @@ gw: ...@@ -129,6 +126,13 @@ gw:
    uid: musa-5 uid: musa-5
    36: 36:
    uid: musa-6 uid: musa-6
    37:
    uid: gwol-south
    kind: server
    38:
    uid: sw-4
    kind: switch
    rate: 10000000000
    40: 40:
    uid: lag4 uid: lag4
    sw-4:
    model: Dell PowerSwitch N1548
    serial: BSWVNK2
    warranty: 2024-04-21
    kind: switch
    managed_by_us: true
    site: sophia
    snmp_community: public
    ip: 172.17.143.244
    backplane_bps: 176_000_000_0000
    metrics:
    - name: network_ifacein_bytes_total
    description: Input byte counter for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.31.1.1.1.6.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifaceout_bytes_total
    description: Output byte counter for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.31.1.1.1.10.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifacein_packets_total
    description: Input packet counter for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.11.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifaceout_packets_total
    description: Output packet counter for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.17.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifacein_packets_discard_total
    description: Input counter of discarded packets for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.13.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifaceout_packets_discard_total
    description: Output counter of discarded packets for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.19.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifacein_packets_error_total
    description: Input counter of packet errors for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.14.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    - name: network_ifaceout_packets_error_total
    description: Output counter of packet errors for the network device port
    period: 15000
    source:
    protocol: snmp
    id: 1.3.6.1.2.1.2.2.1.20.{{ 1.3.6.1.2.1.2.2.1.2 == %SNMP_IFACE% }}
    linecards:
    0:
    snmp_pattern: "Gigabitethernet 1/%LINECARD%/%PORT%"
    kavlan_pattern: "%PORT%"
    rate: 1_000_000_000
    kind: node
    ports:
    1:
    uid: mercantour3-3
    2:
    uid: mercantour3-4
    3:
    uid: mercantour3-7
    4:
    uid: mercantour3-8
    5:
    uid: mercantour3-11
    6:
    uid: mercantour3-12
    7:
    uid: mercantour3-15
    8:
    uid: mercantour3-16
    25:
    uid: mercantour3-1
    26:
    uid: mercantour3-2
    27:
    uid: mercantour3-5
    28:
    uid: mercantour3-6
    29:
    uid: mercantour3-9
    30:
    uid: mercantour3-10
    31:
    uid: mercantour3-13
    32:
    uid: mercantour3-14
    1:
    snmp_pattern: "TenGigabitEthernet %LINECARD%/0/%PORT%"
    rate: 10_000_000_000
    kind: node
    ports:
    1:
    uid: gw
    kind: router
