Commit 828903db authored by Jonathan Pastor's avatar Jonathan Pastor
handle 'diff,print' action
parent 31c5f5f5
1 merge request!6WIP: Features/oar gpus
Pipeline #107077 passed
......@@ -204,25 +204,42 @@ end
# (3) > * If the resource already exists, the CPU and CORE associated to the resource is detected
# (4) * The resource is exported as an OAR command
# (5) * If applicable, create/update the storage devices associated to the node
def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties, data_hierarchy)
def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties, data_hierarchy, faulty_resources=nil, faulty_nodes=nil)
result = ""
# Generate helper functions and detect the next available CPU and CORE IDs for
# non exisiting resources
result += generate_oar_commands_header()
print_header = true
# Ensure that OAR properties exist before creating/updating OAR resources
result += generate_oar_property_creation(site_name, data_hierarchy)
if not faulty_nodes.nil? or not faulty_resources.nil?
print_header = false
if print_header
# Iterate over nodes of the generated resource hierarchy
generated_hierarchy[:nodes].each do |node|
result += %Q{
print_node_header = true
if not faulty_nodes.nil? and not faulty_nodes.include?(node[:fqdn])
print_node_header = false
if print_node_header
result += %Q{
# #{node[:fqdn]}
# Iterate over the resources of the OAR node
node[:oar_rows].each do |oar_ressource_row|
......@@ -237,6 +254,10 @@ def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties,
gpudevicepath = oar_ressource_row[:gpudevicepath].to_s
resource_id = oar_ressource_row[:resource_id]
if not faulty_resources.nil? and not faulty_resources.include?(resource_id)
next
if resource_id == -1 or resource_id.nil?
# Add the resource to the OAR DB
if gpu == ''
......@@ -254,8 +275,15 @@ def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties,
# Set the OAR properties of the OAR node
result += generate_set_node_properties_cmd(node[:fqdn], node[:default_description])
print_node = true
if not faulty_nodes.nil? and not faulty_nodes.include?(node[:name])
print_node = false
if print_node
# Iterate over storage devices
node[:description]["storage_devices"].select{|v| v.key?("reservation") and v["reservation"]}.each do |storage_device|
......@@ -268,6 +296,10 @@ def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties,
storage_device_name = storage_device["device"]
storage_device_name_with_hostname = "#{storage_device_name}.#{node[:name]}"
if not faulty_nodes.nil? and not faulty_nodes.include?(storage_device_name_with_hostname)
next
# Retried the site propertie that corresponds to this storage device
storage_device_oar_properties_tuple = site_properties["disk"].select { |keys| keys.include?(storage_device_name_with_hostname) }.first
......@@ -285,7 +317,9 @@ def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties,
result += generate_set_disk_properties_cmd(node[:fqdn], storage_device_name_with_hostname, storage_device_oar_properties)
result += generate_separators()
if print_node
return result
......@@ -802,6 +836,11 @@ end
def do_diff(options, generated_hierarchy, refrepo_properties)
ret = 0
diagnostic_msgs = []
faulty_resources = []
faulty_nodes = []
properties = {
'ref' => refrepo_properties,
'oar' => get_oar_properties_from_oar(options)
......@@ -835,7 +874,7 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
if missings_alive.size > 0
puts "*** Error: The following nodes exist in the OAR server but are missing in the reference-repo: #{missings_alive.join(', ')}.\n"
diagnostic_msgs.push("*** Error: The following nodes exist in the OAR server but are missing in the reference-repo: #{missings_alive.join(', ')}.\n")
ret = false unless options[:update] || options[:print]
......@@ -864,6 +903,14 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
diff_keys = diff.map { |hashdiff_array| hashdiff_array[1] }
properties['diff'][site_uid][type][key] = properties_ref.select { |k, _v| diff_keys.include?(k) }
if not diff.empty?
if key.kind_of?(Array)
faulty_nodes.push(key[-1])
else
faulty_nodes.push(key)
# Verbose output
if properties['oar'][site_uid][type][key].nil?
info = ((type == 'default') ? ' new node !' : ' new disk !')
......@@ -873,27 +920,27 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
case options[:verbose]
when 1
puts "#{key}:#{info}" if info != ''
puts "#{key}:#{diff_keys}" if diff.size != 0
diagnostic_msgs.push( "#{key}:#{info}") if info != ''
diagnostic_msgs.push( "#{key}:#{diff_keys}") if diff.size != 0
when 2
# Give more details
if header == false
puts "Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed"
diagnostic_msgs.push( "Output format: [ '-', 'key', 'value'] for missing, [ '+', 'key', 'value'] for added, ['~', 'key', 'old value', 'new value'] for changed")
header = true
if diff.empty?
puts " #{key}: OK#{info}"
diagnostic_msgs.push( " #{key}: OK#{info}")
elsif diff == prev_diff
puts " #{key}:#{info} same modifications as above"
diagnostic_msgs.push( " #{key}:#{info} same modifications as above")
else
puts " #{key}:#{info}"
diff.each { |d| puts " #{d}" }
diagnostic_msgs.push( " #{key}:#{info}")
diff.each { |d| diagnostic_msgs.push( " #{d}") }
prev_diff = diff
when 3
# Even more details
puts JSON.pretty_generate(key => { 'old values' => properties_oar, 'new values' => properties_ref })
diagnostic_msgs.push( JSON.pretty_generate(key => { 'old values' => properties_oar, 'new values' => properties_ref }))
if diff.size != 0
......@@ -911,12 +958,12 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
properties_keys['diff'][site_uid][k] = v_ref unless v_oar
if v_oar && v_oar != v_ref && v_ref != NilClass && v_oar != NilClass
# Detect inconsistency between the type (String/Fixnum) of properties generated by this script and the existing values on the server.
puts "Error: the OAR property '#{k}' is a '#{v_oar}' on the #{site_uid} server and this script uses '#{v_ref}' for this property."
diagnostic_msgs.push( "Error: the OAR property '#{k}' is a '#{v_oar}' on the #{site_uid} server and this script uses '#{v_ref}' for this property.")
puts "Properties that need to be created on the #{site_uid} server: #{properties_keys['diff'][site_uid].keys.to_a.delete_if { |e| ignore_default_keys.include?(e) }.join(', ')}" if options[:verbose] && properties_keys['diff'][site_uid].keys.to_a.delete_if { |e| ignore_default_keys.include?(e) }.size > 0
diagnostic_msgs.push( "Properties that need to be created on the #{site_uid} server: #{properties_keys['diff'][site_uid].keys.to_a.delete_if { |e| ignore_default_keys.include?(e) }.join(', ')}") if options[:verbose] && properties_keys['diff'][site_uid].keys.to_a.delete_if { |e| ignore_default_keys.include?(e) }.size > 0
# Detect unknown properties
unknown_properties = properties_keys['oar'][site_uid].keys.to_set - properties_keys['ref'][site_uid].keys.to_set
......@@ -925,17 +972,21 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
if options[:verbose] && unknown_properties.size > 0
puts "Properties existing on the #{site_uid} server but not managed/known by the generator: #{unknown_properties.to_a.join(', ')}."
puts "Hint: you can delete properties with 'oarproperty -d <property>' or add them to the ignore list in lib/lib-oar-properties.rb."
diagnostic_msgs.push( "Properties existing on the #{site_uid} server but not managed/known by the generator: #{unknown_properties.to_a.join(', ')}.")
diagnostic_msgs.push( "Hint: you can delete properties with 'oarproperty -d <property>' or add them to the ignore list in lib/lib-oar-properties.rb.")
puts "Skipped retired nodes: #{skipped_nodes}" if skipped_nodes.any?
diagnostic_msgs.push( "Skipped retired nodes: #{skipped_nodes}") if skipped_nodes.any?
if not (options[:print] and options[:diff])
diagnostic_msgs.map{|msg| puts(msg)}
# Check that CPUSETs on the OAR server are consistent with what would have been generated
oar_resources = get_oar_resources_from_oar(options)
diagnostic_msgs = ""
error_msgs = ""
options[:clusters].each do |cluster|
......@@ -965,7 +1016,9 @@ def do_diff(options, generated_hierarchy, refrepo_properties)
diagnostic_msg = <<-TXT
# Error: Resource #{resc["id"]} (host=#{resc["network_address"]} cpu=#{resc["cpu"]} core=#{resc["core"]} cpuset=#{resc["cpuset"]} gpu=#{resc["gpu"]} gpudevice=#{resc["gpudevice"]}) has a mismatch for ressource #{value.upcase}: OAR API gives #{resc[value]}, generator wants #{expected_value}.
TXT
diagnostic_msgs += "#{diagnostic_msg}"
error_msgs += "#{diagnostic_msg}"
faulty_resources.push(row[:resource_id])
faulty_resources.push(row[:host])
else
......@@ -973,21 +1026,23 @@ TXT
# however it cannot be found : the generator reports an error to the operator
if row[:resource_id] != -1
puts "Error: could not find ressource with ID=#{row[:resource_id]}"
if not diagnostic_msgs.empty?
puts diagnostic_msgs
if not (options[:print] and options[:diff]) and not error_msgs.empty?
puts error_msgs
end # if options[:diff]
return ret
return ret, faulty_resources, faulty_nodes
......@@ -1466,16 +1521,23 @@ def generate_oar_properties(options)
export_rows_as_formated_line(generated_hierarchy)
# Do=Diff
if options.key? :diff and options[:diff]
return_code, faulty_resources, faulty_nodes = do_diff(options, generated_hierarchy, refrepo_properties)
ret = return_code
# DO=print
if options.key? :print and options[:print]
cmds = export_rows_as_oar_command(generated_hierarchy, site_name, refrepo_properties[site_name], data_hierarchy)
if options[:diff]
cmds = export_rows_as_oar_command(generated_hierarchy, site_name, refrepo_properties[site_name], data_hierarchy, faulty_resources, faulty_nodes)
else
puts(cmds)
# Do=Diff
ret = do_diff(options, generated_hierarchy, refrepo_properties)
# Do=update
if options[:update]
......@@ -489,6 +489,64 @@ TXT
context 'OAR server with data' do
before do
prepare_stubs("dump_oar_api_configured_server.json", "load_data_hierarchy_stubbed_data.json")
it 'should generate correctly a table of nodes' do
uri = URI(conf["uri"])
response = Net::HTTP.get(uri)
expect(response).to be_an_instance_of(String)
options = {
:table => true,
:print => false,
:update => false,
:diff => false,
:site => "fakesite",
:clusters => ["clustera"]
expected_header = <<-TXT
| cluster | host | cpu | core | cpuset | gpu | gpudevice | cpumodel | gpumodel |
TXT
expected_clustera1_desc = <<-TXT
| clustera | clustera-1 | 1 | 1 | 0 | 1 | 0 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-1 | 1 | 2 | 1 | 1 | 0 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-1 | 1 | 3 | 2 | 1 | 0 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-1 | 1 | 4 | 3 | 1 | 0 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-1 | 1 | 5 | 4 | 2 | 1 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-1 | 1 | 6 | 5 | 2 | 1 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
TXT
expected_clustera2_desc = <<-TXT
| clustera | clustera-2 | 4 | 26 | 9 | 7 | 2 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 27 | 10 | 7 | 2 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 28 | 11 | 7 | 2 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 29 | 12 | 8 | 3 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 30 | 13 | 8 | 3 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 31 | 14 | 8 | 3 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
| clustera | clustera-2 | 4 | 32 | 15 | 8 | 3 | Intel Xeon Silver 4110 | GeForce RTX 2080 Ti |
TXT
generator_output = capture do
expect(generator_output[:stdout]).to include(expected_header)
expect(generator_output[:stdout]).to include(expected_clustera1_desc)
expect(generator_output[:stdout]).to include(expected_clustera2_desc)
context 'interracting with an empty OAR server (round-robin cpusets)' do
before do
prepare_stubs("dump_oar_api_empty_server.json", "load_data_hierarchy_stubbed_data_round_robin_cpusets.json")
......@@ -1774,6 +1832,34 @@ TXT
expect(generator_output[:stdout]).to include(expected_output)
it 'should print commands to correct the cluster' do
options = {
:table => false,
:print => false,
:update => false,
:diff => true,
expected_output = <<-TXT
# Error: Resource 9 (host=clustera-1.fakesite.grid5000.fr cpu=2 core=9 cpuset=8 gpu=2 gpudevice=2) has a mismatch for ressource GPU: OAR API gives 2, generator wants 3.
TXT
context 'interracting with a configured OAR server (msising network interfaces)' do
......@@ -2268,4 +2354,64 @@ CORE has an unexpected number of resources (current:31 vs expected:32).
context 'interracting with a cluster with misconfigured resources, errors in its OAR properties and some misconfigured disks' do
before do
prepare_stubs("dump_oar_api_configured_server_with_disk_misconfigured_resources_properties_and_disks.json", "load_data_hierarchy_stubbed_data_with_disk.json")
it 'should handle "diff,print" action' do
options = {
:table => false,
:print => true,
:update => false,
:diff => true,
:clusters => ["clusterb"],
:verbose => 2
oarnodesetting --sql "host='clusterb-2.fakesite.grid5000.fr' and type='default'" -p ip='172.16.64.2' -p cluster='clusterb' -p nodemodel='Dell PowerEdge T640' -p virtual='ivt' -p cpuarch='x86_64' -p cpucore=8 -p cputype='Intel Xeon Silver 4110' -p cpufreq='2.1' -p disktype='SATA' -p eth_count=1 -p eth_rate=10 -p ib_count=0 -p ib_rate=0 -p ib='NO' -p opa_count=0 -p opa_rate=0 -p opa='NO' -p myri_count=0 -p myri_rate=0 -p myri='NO' -p memcore=8192 -p memcpu=65536 -p memnode=131072 -p gpu_count=4 -p mic='NO' -p wattmeter='MULTIPLE' -p cluster_priority=201906 -p max_walltime=86400 -p production='YES' -p maintenance='NO' -p disk_reservation_count=3
TXT
expected_output2 = <<-TXT
oarnodesetting --sql "host='clusterb-1.fakesite.grid5000.fr' and type='default'" -p ip='172.16.64.1' -p cluster='clusterb' -p nodemodel='Dell PowerEdge T640' -p virtual='ivt' -p cpuarch='x86_64' -p cpucore=8 -p cputype='Intel Xeon Silver 4110' -p cpufreq='2.1' -p disktype='SATA' -p eth_count=1 -p eth_rate=10 -p ib_count=0 -p ib_rate=0 -p ib='NO' -p opa_count=0 -p opa_rate=0 -p opa='NO' -p myri_count=0 -p myri_rate=0 -p myri='NO' -p memcore=8192 -p memcpu=65536 -p memnode=131072 -p gpu_count=4 -p mic='NO' -p wattmeter='MULTIPLE' -p cluster_priority=201906 -p max_walltime=86400 -p production='YES' -p maintenance='NO' -p disk_reservation_count=3
TXT
expected_output3 = <<-TXT
echo '================================================================================'
echo; echo 'Adding disk sdb.clusterb-1 on host clusterb-1.fakesite.grid5000.fr:'
disk_exist 'clusterb-1.fakesite.grid5000.fr' 'sdb.clusterb-1' && echo '=> disk already exists'
disk_exist 'clusterb-1.fakesite.grid5000.fr' 'sdb.clusterb-1' || oarnodesetting -a -h '' -p host='clusterb-1.fakesite.grid5000.fr' -p type='disk' -p disk='sdb.clusterb-1'
echo; echo 'Setting properties for disk sdb.clusterb-1 on host clusterb-1.fakesite.grid5000.fr:'; echo
oarnodesetting --sql "host='clusterb-1.fakesite.grid5000.fr' and type='disk' and disk='sdb.clusterb-1'" -p cluster='clusterb' -p host='clusterb-1.fakesite.grid5000.fr' -p available_upto=0 -p deploy='YES' -p production='YES' -p maintenance='NO' -p disk='sdb.clusterb-1' -p diskpath='/dev/disk/by-path/pci-0000:02:00.0-scsi-0:0:1:0' -p cpuset=-1
TXT
expected_output4 = <<-TXT
oarnodesetting --sql "host='clusterb-2.fakesite.grid5000.fr' AND resource_id='33' AND type='default'" -p cpu=4 -p core=30 -p cpuset=13 -p gpu=8 -p gpu_model='GeForce RTX 2080 Ti' -p gpudevice=3 # This GPU is mapped on /dev/nvidia3
TXT
dont_expected_output5 = <<-TXT
echo; echo 'Adding disk sdb.clusterb-2 on host clusterb-1.fakesite.grid5000.fr:'
TXT
expect(generator_output[:stdout]).to include(expected_output2)
expect(generator_output[:stdout]).to include(expected_output3)
expect(generator_output[:stdout]).to include(expected_output4)
expect(generator_output[:stdout]).not_to include(dont_expected_output5)
