Commit 7eb85509 authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[nancy] Added ip/mac of pdus and MIC for the dhcp generator. Also fixed some MAC addresses.
parent fb5f529f
...@@ -714,8 +714,8 @@ nodes: ...@@ -714,8 +714,8 @@ nodes:
network_adapters: network_adapters:
bmc: bmc:
ip: 172.17.64.29 ip: 172.17.64.29
#mac: 00:e0:81:d5:06:57 # should be check mac: 00:e0:81:d5:06:57 # according to the DHCP config
mac: 00:e0:81:d5:07:f3 #mac: 00:e0:81:d5:07:f3
eth0: eth0:
ip6: fe80::2e0:81ff:fed5:654 ip6: fe80::2e0:81ff:fed5:654
graphene-30: graphene-30:
...@@ -56,8 +56,8 @@ graphene-28: ...@@ -56,8 +56,8 @@ graphene-28:
driver: e1000e driver: e1000e
mountable: false mountable: false
bmc: bmc:
#mac: 00:e0:81:d5:07:f3 #TODO: should be check mac: 00:e0:81:d5:07:f3 # according to the DHCP config
mac: 00:e0:81:d5:06:5f #mac: 00:e0:81:d5:06:5f
ip: 172.17.64.28 ip: 172.17.64.28
storage_devices: storage_devices:
sda: sda:
...@@ -71,4 +71,5 @@ graphique-3: ...@@ -71,4 +71,5 @@ graphique-3:
rate: 1000000000 rate: 1000000000
bmc: bmc:
ip: 172.17.67.3 ip: 172.17.67.3
mac: 18:fb:7b:9b:68:d3 #mac: 18:fb:7b:9b:68:d3
mac: 18:fb:7b:9b:91:6D # according to the DHCP config
\ No newline at end of file
...@@ -64,7 +64,8 @@ graphique-4: ...@@ -64,7 +64,8 @@ graphique-4:
bmc: bmc:
ip: 172.17.67.4 ip: 172.17.67.4
mac: 18:fb:7b:9b:91:6d #mac: 18:fb:7b:9b:91:6d
mac: B0:83:FE:E4:69:D8 # according to the DHCP config
chassis: chassis:
serial: HYTRV42 serial: HYTRV42
manufacturer: Dell Inc. manufacturer: Dell Inc.
...@@ -125,6 +125,10 @@ nodes: ...@@ -125,6 +125,10 @@ nodes:
sda: sda:
timeread: 959 timeread: 959
timewrite: 2205 timewrite: 2205
mic:
ip: 172.16.68.5
mac: 4C:79:BA:5C:01:74
graphite-2: graphite-2:
chassis: chassis:
serial: B6Q7NZ1 serial: B6Q7NZ1
...@@ -136,6 +140,10 @@ nodes: ...@@ -136,6 +140,10 @@ nodes:
sda: sda:
timeread: 956 timeread: 956
timewrite: 1991 timewrite: 1991
mic:
ip: 172.16.68.6
mac: 4C:79:BA:5C:01:18
graphite-3: graphite-3:
chassis: chassis:
serial: G5Q7NZ1 serial: G5Q7NZ1
...@@ -150,6 +158,10 @@ nodes: ...@@ -150,6 +158,10 @@ nodes:
sda: sda:
timeread: 958 timeread: 958
timewrite: 2963 timewrite: 2963
mic:
ip: 172.16.68.87
mac: 4C:79:BA:5C:01:AC
graphite-4: graphite-4:
chassis: chassis:
serial: 66Q7NZ1 serial: 66Q7NZ1
...@@ -164,3 +176,6 @@ nodes: ...@@ -164,3 +176,6 @@ nodes:
sda: sda:
timeread: 978 timeread: 978
timewrite: 3300 timewrite: 3300
mic:
ip: 172.16.68.8
mac: 4C:79:BA:5C:01:0C
...@@ -76,3 +76,42 @@ pdus: ...@@ -76,3 +76,42 @@ pdus:
unit: W unit: W
outlet_prefix_oid: iso.3.6.1.4.1.318.1.1.26.9.4.3.1.7 outlet_prefix_oid: iso.3.6.1.4.1.318.1.1.26.9.4.3.1.7
graoully-pdu1:
ip: 172.17.79.243
mac: 00:C0:B7:85:24:B7
graoully-pdu2:
ip: 172.17.79.244
mac: 00:C0:B7:85:13:9C
graphene-pdu1:
ip: 172.17.79.208
mac: 00:C0:B7:4D:A4:B0
graphene-pdu2:
ip: 172.17.79.209
mac: 00:C0:B7:4D:A4:A3
graphene-pdu3:
ip: 172.17.79.210
mac: 00:C0:B7:4D:A4:AA
graphene-pdu4:
ip: 172.17.79.211
mac: 00:C0:B7:4D:A4:BC
graphene-pdu5:
ip: 172.17.79.212
mac: 00:C0:B7:4D:A4:AC
graphene-pdu6:
ip: 172.17.79.213
mac: 00:C0:B7:4D:A1:87
graphene-pdu7:
ip: 172.17.79.214
mac: 00:C0:B7:4D:D7:87
graphene-pdu8:
ip: 172.17.79.215
...@@ -60,6 +60,24 @@ global_hash["sites"].each { |site_uid, site_hash| ...@@ -60,6 +60,24 @@ global_hash["sites"].each { |site_uid, site_hash|
# Relocate ip/mac info of pdus
site_hash['pdus'].each { |pdu_uid, pdu_hash|
if pdu_hash['ip'] && pdu_hash['mac']
pdu_hash['network_adapters'] ||= {}
pdu_hash['network_adapters']['pdu'] ||= {}
pdu_hash['network_adapters']['pdu']['ip'] = pdu_hash.delete('ip')
pdu_hash['network_adapters']['pdu']['mac'] = pdu_hash.delete('mac')
key = 'pdus'
write_dhcp_file({
"filename" => key + ".conf",
"site_uid" => site_uid,
"nodes" => site_hash['pdus'],
"network_adapters" => ['pdu'],
next next
# Other dhcp files # Other dhcp files
