Commit 735c3641 authored by Lucas Nussbaum's avatar Lucas Nussbaum
Use bundler and document it
parent 26bbab4a
Pipeline #92051 failed
...@@ -3,3 +3,4 @@ ...@@ -3,3 +3,4 @@
dev/run-g5kchecks/output/ dev/run-g5kchecks/output/
generators/run-g5kchecks/output/ generators/run-g5kchecks/output/
bundle
...@@ -95,4 +95,4 @@ DEPENDENCIES ...@@ -95,4 +95,4 @@ DEPENDENCIES
ruby-cute ruby-cute
BUNDLED WITH BUNDLED WITH
2.0.2 1.17.3
...@@ -21,6 +21,17 @@ See also: ...@@ -21,6 +21,17 @@ See also:
* .gitlab-ci.yml, that automates various checks and the deployment of data files after each commit * .gitlab-ci.yml, that automates various checks and the deployment of data files after each commit
* doc/README.generators.md * doc/README.generators.md
# Setup
We use bundler to manage dependencies.
apt install bundler
bundler install --standalone # this installs dependencies in the 'bundle' directory
rake reference-api # or other commands
# Credentials # Credentials
all tools that require to authenticate against Grid'5000 use credentials from ~/.grid5000_api.yml. Example: all tools that require to authenticate against Grid'5000 use credentials from ~/.grid5000_api.yml. Example:
require 'bundler/setup'
if ENV['COV'] if ENV['COV']
require 'simplecov' require 'simplecov'
SimpleCov.start SimpleCov.start
