Commit 6cc09130 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[dev/wiki] Improve footer (bug 9289)
parent 9182a0c2
...@@ -53,7 +53,7 @@ class CPUParametersGenerator < WikiGenerator ...@@ -53,7 +53,7 @@ class CPUParametersGenerator < WikiGenerator
#Table construction #Table construction
table_options = 'class="wikitable sortable"' table_options = 'class="wikitable sortable"'
@generated_content = MW.generate_table(table_options, table_columns, table_data) @generated_content = MW.generate_table(table_options, table_columns, table_data)
@generated_content += MW.italic(MW.small("Generated from the Grid5000 APIs on " + Time.now.strftime("%Y-%m-%d"))) @generated_content += MW.italic(MW.small(generated_date_string))
@generated_content += MW::LINE_FEED @generated_content += MW::LINE_FEED
end end
end end
...@@ -42,7 +42,7 @@ class DiskReservationGenerator < WikiGenerator ...@@ -42,7 +42,7 @@ class DiskReservationGenerator < WikiGenerator
# Table construction # Table construction
end end
...@@ -17,7 +17,7 @@ class G5KHardwareGenerator < WikiGenerator ...@@ -17,7 +17,7 @@ class G5KHardwareGenerator < WikiGenerator
@generated_content += "\n= Clusters =\n" @generated_content += "\n= Clusters =\n"
@generated_content += SiteHardwareGenerator.generate_all_clusters @generated_content += SiteHardwareGenerator.generate_all_clusters
@generated_content += generate_totals @generated_content += generate_totals
end end
...@@ -219,6 +219,8 @@ class OarPropertiesGenerator < WikiGenerator ...@@ -219,6 +219,8 @@ class OarPropertiesGenerator < WikiGenerator
@generated_content += MW::LIST_ITEM + " Possible values: " + MW::code(@@properties[property]["possible_values"]) + MW::LINE_FEED @generated_content += MW::LIST_ITEM + " Possible values: " + MW::code(@@properties[property]["possible_values"]) + MW::LINE_FEED
end end
end end
...@@ -16,7 +16,7 @@ class SiteHardwareGenerator < WikiGenerator ...@@ -16,7 +16,7 @@ class SiteHardwareGenerator < WikiGenerator
@generated_content += "'''#{generate_oneline_summary}'''\n" @generated_content += "'''#{generate_oneline_summary}'''\n"
@generated_content += self.class.generate_summary(@site, false) @generated_content += self.class.generate_summary(@site, false)
@generated_content += self.class.generate_description(@site) @generated_content += self.class.generate_description(@site)
@generated_content += MW.italic(MW.small('Generated from the Grid5000 APIs on ' + Time.now.strftime('%Y-%m-%d'))) @generated_content += MW.italic(MW.small(generated_date_string))
end end
...@@ -42,6 +42,16 @@ class WikiGenerator ...@@ -42,6 +42,16 @@ class WikiGenerator
raise "To be implemented in actual generators" raise "To be implemented in actual generators"
end end
def remove_page_creation_date(content)
return content.gsub(/''<small>Last generated from the Grid5000 API on .+<\/small>''/, '')
def generated_date_string
commit = `git show --oneline -s`.split(' ').first
date = Time.now.strftime("%Y-%m-%d")
return "Last generated from the Grid5000 Reference API on #{date} ([https://github.com/grid5000/reference-repository/commit/#{commit} commit #{commit}])"
#Actually edit the mediawiki page with the new generated content #Actually edit the mediawiki page with the new generated content
def update_page def update_page
@mw_client.edit({"title" => @page_name, "text" => @generated_content }) @mw_client.edit({"title" => @page_name, "text" => @generated_content })
...@@ -64,10 +74,6 @@ class WikiGenerator ...@@ -64,10 +74,6 @@ class WikiGenerator
return false return false
end end
return content.gsub(/''<small>Generated from the Grid5000 APIs on .+<\/small>''/, '')
def update_files def update_files
@files.each { |file| @files.each { |file|
@mw_client.update_file(file['filename'], file['path'], file['content_type'], file['comment'], true) @mw_client.update_file(file['filename'], file['path'], file['content_type'], file['comment'], true)
...@@ -112,7 +118,7 @@ class WikiGenerator ...@@ -112,7 +118,7 @@ class WikiGenerator
options = { options = {
:generators => [], :generators => [],
:sites => G5K::SITES, :sites => ['global'] + G5K::SITES,
:diff => false, :diff => false,
:print => false, :print => false,
:update => false, :update => false,
