GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.3.
Show more breadcrumbs
grid5000
6c38852c
6c38852c
2 months ago
DOMINOIS Hugo
Committed by
DOMINOIS Hugo
2 months ago
Downloads
Patches
[sophia][esterel1] Add metrics
70fd5ed8
1 merge request
!1102
esterel1 into master
2
2 changed files
data/grid5000/sites/sophia/clusters/esterel1/esterel1.json
+72
-1
72 additions, 1 deletion
input/grid5000/sites/sophia/clusters/esterel1/esterel1_metrics.yaml
+60
60 additions, 0 deletions
...5000/sites/sophia/clusters/esterel1/esterel1_metrics.yaml
132 additions
1 deletion
72
6c38852c
@@ -5,7 +5,78 @@
@@ -5,7 +5,78 @@
"kavlan"
false
"kavlan"
false
"manufactured_at"
"2016-11-01"
"manufactured_at"
"2016-11-01"
"metrics"
"metrics"
"description"
"Default subset of metrics from Prometheus Node Exporter"
"name"
"prom_default_metrics"
"optional_period"
15000
"period"
"source"
"id"
"node_boot_time_seconds"
"node_cpu_scaling_frequency_hertz"
"node_cpu_seconds_total"
"node_filesystem_free_bytes"
"node_filesystem_size_bytes"
"node_load1"
"node_load15"
"node_load5"
"node_memory_Buffers_bytes"
"node_memory_Cached_bytes"
"node_memory_MemAvailable_bytes"
"node_memory_MemFree_bytes"
"node_memory_MemTotal_bytes"
"node_memory_Shmem_bytes"
"node_memory_SwapFree_bytes"
"node_memory_SwapTotal_bytes"
"node_network_receive_bytes_total"
"node_network_receive_packets_total"
"node_network_transmit_bytes_total"
"node_network_transmit_packets_total"
"node_procs_blocked"
"node_procs_running"
"kwollect_custom"
"port"
9100
"protocol"
"prometheus"
"description"
"All metrics from Prometheus Node Exporter"
"name"
"prom_all_metrics"
"optional_period"
15000
"period"
"source"
"port"
9100
"protocol"
"prometheus"
"description"
"Default subset of metrics from Prometheus Nvidia DCGM Exporter"
"name"
"prom_nvgpu_default_metrics"
"optional_period"
15000
"period"
"source"
"id"
"DCGM_FI_DEV_SM_CLOCK"
"DCGM_FI_DEV_MEM_CLOCK"
"DCGM_FI_DEV_GPU_TEMP"
"DCGM_FI_DEV_POWER_USAGE"
"DCGM_FI_DEV_MEM_COPY_UTIL"
"port"
9400
"protocol"
"prometheus"
"description"
"All metrics from Prometheus Nvidia DCGM Exporter"
"name"
"prom_nvgpu_all_metrics"
"optional_period"
15000
"period"
"source"
"port"
9400
"protocol"
"prometheus"
"model"
"Dell PowerEdge R730"
"model"
"nodes_count"
"nodes_count"
This diff is collapsed.
60
6c38852c
metrics
name
description
period
optional_period
15000
source
protocol
prometheus
port
9100
id
node_load1
node_load15
node_load5
node_procs_blocked
node_procs_running
kwollect_custom
name
prom_all_metrics
description
period
optional_period
15000
source
protocol
prometheus
port
9100
name
description
period
optional_period
15000
source
protocol
prometheus
port
9400
id
name
description
period
optional_period
15000
source
protocol
prometheus
port
9400
Loading
Save comment
