Commit 602028f2 authored by RINGOT Patrice's avatar RINGOT Patrice
[nancy] initial import of graffiti
parent f4e58d39
with 941 additions and 0 deletions
"created_at": "Thu, 06 Jun 2019 22:00:00 GMT",
"kavlan": false,
"model": "Dell PowerEdge T640",
"queues": [
"admin",
"testing"
"type": "cluster",
"uid": "graffiti"
\ No newline at end of file
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"wattmeter": "false"
"network_adapters": [
"device": "eth0",
"enabled": true,
"ip": "172.16.64.1",
"kavlan": false,
"mac": "ee:ee:ee:ee:ee:ee",
"mountable": true,
"mounted": true,
"network_address": "graffiti-1.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"interface": "Ethernet",
"ip": "172.17.64.1",
"kavlan": false,
"mac": "f4:02:70:9a:3f:74",
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"microarchitecture": "Skylake"
"sensors": {
"storage_devices": [
"device": "sda",
"driver": "megaraid_sas",
"interface": "SATA",
"model": "PERC H330",
"storage": "SSD",
"vendor": "Dell (Raid)"
"supported_job_types": {
"besteffort": true,
"deploy": true,
"max_walltime": 86400,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-1"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-10.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"max_walltime": 604800,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-10"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-11.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-11"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-12.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-12"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-13.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-13"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"ip": "172.16.64.2",
"kavlan": false,
"mac": "dd:dd:dd:2c:a5:80",
"mountable": true,
"mounted": true,
"network_address": "graffiti-2.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"ip": "172.17.64.2",
"kavlan": false,
"mac": "f4:02:70:9a:48:e8",
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-2"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-3.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-3"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-4.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"max_walltime": 172800,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-4"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-5.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-5"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-6.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-6"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-7.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-7"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-8.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-8"
"gpu": {
"gpu": false
"kavlan": {
"main_memory": {
"monitoring": {
"device": "eth0",
"enabled": true,
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graffiti-9.nancy.grid5000.fr",
"switch": null,
"switch_port": null
"device": "eth1",
"enabled": false,
"kavlan": false,
"mountable": false,
"mounted": false
"device": "bmc",
"enabled": true,
"kavlan": false,
"mountable": false,
"mounted": false
"processor": {
"cache_l1": null,
"sensors": {
"device": "sda",
"storage": "SSD",
"besteffort": true,
"deploy": true,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "graffiti-9"
model: Dell PowerEdge T640
created_at: 2019-06-07
kavlan: false
queues:
- admin
- testing
nodes:
graffiti-[1-13]:
processor:
microarchitecture: Skylake
supported_job_types:
deploy: true
besteffort: true
queues:
- admin
- testing
network_adapters:
bmc:
interface: Ethernet
enabled: true
mountable: false
mounted: false
eth0:
enabled: true
mountable: true
mounted: true
eth1:
enabled: false
mountable: false
mounted: false
storage_devices:
sda:
interface: SATA
driver: megaraid_sas
storage: SSD
model: PERC H330
graffiti-[1-3]:
max_walltime: 86400
graffiti-[4-6]:
max_walltime: 172800
graffiti-[7-]:
max_walltime: 604800
nodes:
<% (1..2).each { |i| %>
graffiti-<%= i %>:
network_adapters:
eth0:
mounted: true
ip: 172.16.64.<%= i %>
mac: <%= %w(
EE:EE:EE:EE:EE:EE
DD:DD:DD:2C:A5:80
)[i-1] %>
bmc:
ip: 172.17.64.<%= i %>
mac: <%= %w(
F4:02:70:9A:3F:74
F4:02:70:9A:48:E8
)[i-1] %>
