Commit 55a2ad22 authored by Hyacinthe Cartiaux's avatar Hyacinthe Cartiaux
[luxembourg] Fix mac addresses for granduc-10
parent d922036c
...@@ -32,7 +32,7 @@ ...@@ -32,7 +32,7 @@
"enabled": true, "enabled": true,
"interface": "Ethernet", "interface": "Ethernet",
"ip": "172.16.176.10", "ip": "172.16.176.10",
"mac": "00:19:b9:f2:0f:50", "mac": "00:22:19:6d:85:0a",
"management": false, "management": false,
"mountable": true, "mountable": true,
"mounted": true, "mounted": true,
...@@ -46,7 +46,7 @@ ...@@ -46,7 +46,7 @@
"driver": "bnx2", "driver": "bnx2",
"enabled": false, "enabled": false,
"mac": "00:19:b9:f2:0f:52", "mac": "00:22:19:6d:85:0c",
"rate": 1000000000 "rate": 1000000000
...@@ -349,11 +349,11 @@ granduc-10: ...@@ -349,11 +349,11 @@ granduc-10:
mac: 00:1c:23:d3:42:56 mac: 00:1c:23:d3:42:56
ip: 172.17.176.10 ip: 172.17.176.10
eth0: eth0:
mac: 00:19:b9:f2:0f:50 mac: 00:22:19:6d:85:0a
ip: 172.16.176.10 ip: 172.16.176.10
switch_port: switch_port:
eth1: eth1:
mac: 00:19:b9:f2:0f:52 mac: 00:22:19:6d:85:0c
ip: 172.18.176.10 ip: 172.18.176.10
eth2: eth2:
mac: 00:1b:21:34:e1:3d mac: 00:1b:21:34:e1:3d
