GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
5309e74a
5309e74a
4 years ago
Alexandre MERLIN
Downloads
Patches
[gen/kadeploy] adapt cluster configuration to kadeploy3.6
3dcd58e6
1 merge request
!262
kadeploy3.6
Pipeline
#305481
passed
3 years ago
Stage: validate
Stage: generate
Stage: deploy
lib/refrepo/gen/puppet/templates/kadeployg5k.conf.erb
+9
-9
9 additions, 9 deletions
9 additions
9 deletions
9
9
5309e74a
@@ -4,18 +4,18 @@
partitioning:
block_device: /dev/sda
deploy_label: DEPLOY
block_device: disk0
script: /etc/kadeploy3
suffix
'partitioning.script'
nil?
"partitioning.sh"
if
'formating.script'
nil?
'formating.script'
empty?
formating_script: /etc/kadeploy3
suffix
'formating.script'
partitions:
tmp: 5
prod: 2
deploy: 3
swap: 1
disk_path:
cluster
'nodes'
values
first
'storage_devices'
reject
disk
disk
'reservation'
each
do
disk
disk
'id'
disk
'by_path'
trusted_deployment:
partition:
/dev/sda
suffix
empty?
"2"
"3"
partition:
disk0/PROD
user: oar
if
'trusted_env'
envs:
@@ -95,10 +95,10 @@ automata:
macrosteps:
SetDeploymentEnv:
- timeout:
'deployment.timeout'
type:
Unt
rusted
type:
T
rusted
retries:
'deployment.retries'
nil?
- timeout:
type:
Kexec
type:
Untrusted
retries:
nil?
BroadcastEnv:
- timeout:
'broadcast.timeout'
This diff is collapsed.
Loading
Save comment
