Commit 4c5c091a authored by Sebastien Philippot's avatar Sebastien Philippot
[nancy] add graphene_retired.yaml.erb for retired nodes
parent 1f158e43
with 366 additions and 2880 deletions
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"platform_type": "x86_64"
"bios": {
"release_date": "02/18/2011",
"vendor": "American Megatrends Inc.",
"version": "V7.01e"
"chassis": {
"manufacturer": "TYAN",
"name": "S5501"
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.1",
"kavlan-11": "10.7.200.93",
"kavlan-12": "10.11.200.93",
"kavlan-13": "10.15.200.93",
"kavlan-14": "10.19.200.93",
"kavlan-16": "10.27.200.93",
"kavlan-18": "10.35.200.93",
"kavlan-19": "10.39.200.93",
"kavlan-2": "192.168.210.1",
"kavlan-20": "10.43.200.93",
"kavlan-21": "10.47.200.93",
"kavlan-3": "192.168.226.1",
"kavlan-4": "10.16.2.1",
"kavlan-5": "10.16.66.1",
"kavlan-6": "10.16.130.1",
"kavlan-7": "10.16.194.1",
"kavlan-8": "10.17.2.1",
"kavlan-9": "10.17.66.1"
"main_memory": {
"ram_size": 17179869184
"monitoring": {
"wattmeter": "shared"
"network_adapters": [
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"interface": "Ethernet",
"ip": "172.16.64.1",
"kavlan": true,
"mac": "00:e0:81:d5:06:80",
"management": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-1.nancy.grid5000.fr",
"rate": 1000000000,
"switch": "sgraphene1",
"switch_port": "GigabitEthernet1/0/2"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:81",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:82",
"mountable": false,
"mounted": false
"device": "ib0",
"driver": "mlx4_core",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:81",
"interface": "InfiniBand",
"ip": "172.18.64.1",
"ip6": "fe80::202:c903:b:9281",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-1-ib0.nancy.grid5000.fr",
"rate": 20000000000,
"switch": "sgrapheneib",
"vendor": "Mellanox",
"version": "MT26418"
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:82",
"kavlan": false,
"mountable": false,
"mounted": false,
"rate": 10000000000,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.1",
"kavlan": false,
"mac": "00:e0:81:d5:06:83",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-1-bmc.nancy.grid5000.fr",
"switch": "sgraphene1-ipmi",
"switch_port": "1/0/25"
"operating_system": {
"cstate_driver": "intel_idle",
"cstate_governor": "menu",
"cstate_max_id": 2,
"ht_enabled": false,
"pstate_driver": "acpi-cpufreq",
"pstate_governor": "performance",
"turboboost_enabled": true
"performance": {
"core_flops": 8024000000.0,
"node_flops": 31010000000.0
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"cache_l3": 8388608,
"clock_speed": 2550000000,
"ht_capable": true,
"instruction_set": "x86-64",
"microarchitecture": "Lynnfield",
"model": "Intel Xeon",
"other_description": "Intel(R) Xeon(R) CPU X3440 @ 2.53GHz",
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu1"
"storage_devices": [
"by_id": "node-was-not-available-to-retrieve-this-value",
"device": "sda",
"driver": "ahci",
"interface": "SATA II",
"model": "Hitachi HDS72103",
"rev": "JPFOA3EA",
"size": 320072933376,
"storage": "HDD",
"vendor": "Hitachi"
"supported_job_types": {
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-1"
\ No newline at end of file
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 1009390125
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.123",
"kavlan-11": "10.7.200.215",
"kavlan-12": "10.11.200.215",
"kavlan-13": "10.15.200.215",
"kavlan-14": "10.19.200.215",
"kavlan-16": "10.27.200.215",
"kavlan-18": "10.35.200.215",
"kavlan-19": "10.39.200.215",
"kavlan-2": "192.168.210.123",
"kavlan-20": "10.43.200.215",
"kavlan-21": "10.47.200.215",
"kavlan-3": "192.168.226.123",
"kavlan-4": "10.16.2.123",
"kavlan-5": "10.16.66.123",
"kavlan-6": "10.16.130.123",
"kavlan-7": "10.16.194.123",
"kavlan-8": "10.17.2.123",
"kavlan-9": "10.17.66.123"
"main_memory": {
"monitoring": {
"wattmeter": "true"
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.123",
"ip6": "fe80::2e0:81ff:fed5:6ac",
"kavlan": true,
"mac": "00:e0:81:d5:06:ac",
"mountable": true,
"mounted": true,
"network_address": "graphene-123.nancy.grid5000.fr",
"rate": 1000000000,
"switch": "sgraphene4",
"switch_port": "GigabitEthernet1/0/19"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:ad",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:ae",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:19",
"ip": "172.18.64.123",
"ip6": "fe80::202:c903:b:9219",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-123-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:1a",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.123",
"kavlan": false,
"mac": "00:e0:81:d5:06:af",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-123-bmc.nancy.grid5000.fr",
"switch": "sgraphene4-ipmi",
"switch_port": "1/0/43"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"port": 23,
"uid": "graphene-pdu7"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-123"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 1009390146
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.144",
"kavlan-11": "10.7.200.236",
"kavlan-12": "10.11.200.236",
"kavlan-13": "10.15.200.236",
"kavlan-14": "10.19.200.236",
"kavlan-16": "10.27.200.236",
"kavlan-18": "10.35.200.236",
"kavlan-19": "10.39.200.236",
"kavlan-2": "192.168.210.144",
"kavlan-20": "10.43.200.236",
"kavlan-21": "10.47.200.236",
"kavlan-3": "192.168.226.144",
"kavlan-4": "10.16.2.144",
"kavlan-5": "10.16.66.144",
"kavlan-6": "10.16.130.144",
"kavlan-7": "10.16.194.144",
"kavlan-8": "10.17.2.144",
"kavlan-9": "10.17.66.144"
"main_memory": {
"monitoring": {
"wattmeter": "true"
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.144",
"ip6": "fe80::2e0:81ff:fed5:6b8",
"kavlan": true,
"mac": "00:e0:81:d5:06:b8",
"mountable": true,
"mounted": true,
"network_address": "graphene-144.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/40"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:b9",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:ba",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:05:f8:5b",
"ip": "172.18.64.144",
"ip6": "fe80::202:c903:5:f85b",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-144-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:05:f8:5c",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.144",
"kavlan": false,
"mac": "00:e0:81:d5:06:bb",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-144-bmc.nancy.grid5000.fr",
"switch_port": "1/0/20"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"port": 24,
"uid": "graphene-pdu8"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-144"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 1009390030
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.28",
"kavlan-11": "10.7.200.120",
"kavlan-12": "10.11.200.120",
"kavlan-13": "10.15.200.120",
"kavlan-14": "10.19.200.120",
"kavlan-16": "10.27.200.120",
"kavlan-18": "10.35.200.120",
"kavlan-19": "10.39.200.120",
"kavlan-2": "192.168.210.28",
"kavlan-20": "10.43.200.120",
"kavlan-21": "10.47.200.120",
"kavlan-3": "192.168.226.28",
"kavlan-4": "10.16.2.28",
"kavlan-5": "10.16.66.28",
"kavlan-6": "10.16.130.28",
"kavlan-7": "10.16.194.28",
"kavlan-8": "10.17.2.28",
"kavlan-9": "10.17.66.28"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.28",
"ip6": "fe80::2e0:81ff:fed5:65c",
"kavlan": true,
"mac": "00:e0:81:d5:07:f0",
"mountable": true,
"mounted": true,
"network_address": "graphene-28.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/27"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:07:f1",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:07:f2",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:8d",
"ip": "172.18.64.28",
"ip6": "fe80::202:c903:b:928d",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-28-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:8e",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.28",
"kavlan": false,
"mac": "00:e0:81:d5:07:f3",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-28-bmc.nancy.grid5000.fr",
"switch_port": "1/0/8"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-28"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 605634005
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.3",
"kavlan-11": "10.7.200.95",
"kavlan-12": "10.11.200.95",
"kavlan-13": "10.15.200.95",
"kavlan-14": "10.19.200.95",
"kavlan-16": "10.27.200.95",
"kavlan-18": "10.35.200.95",
"kavlan-19": "10.39.200.95",
"kavlan-2": "192.168.210.3",
"kavlan-20": "10.43.200.95",
"kavlan-21": "10.47.200.95",
"kavlan-3": "192.168.226.3",
"kavlan-4": "10.16.2.3",
"kavlan-5": "10.16.66.3",
"kavlan-6": "10.16.130.3",
"kavlan-7": "10.16.194.3",
"kavlan-8": "10.17.2.3",
"kavlan-9": "10.17.66.3"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.3",
"ip6": "fe80::2e0:81ff:fed5:870",
"kavlan": true,
"mac": "00:e0:81:d5:08:70",
"mountable": true,
"mounted": true,
"network_address": "graphene-3.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/4"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:08:71",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:08:72",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:91:59",
"ip": "172.18.64.3",
"ip6": "fe80::202:c903:b:9159",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-3-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:91:5a",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.3",
"kavlan": false,
"mac": "00:e0:81:d5:08:73",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-3-bmc.nancy.grid5000.fr",
"switch_port": "1/0/27"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-3"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": null
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.36",
"kavlan-11": "10.7.200.128",
"kavlan-12": "10.11.200.128",
"kavlan-13": "10.15.200.128",
"kavlan-14": "10.19.200.128",
"kavlan-16": "10.27.200.128",
"kavlan-18": "10.35.200.128",
"kavlan-19": "10.39.200.128",
"kavlan-2": "192.168.210.36",
"kavlan-20": "10.43.200.128",
"kavlan-21": "10.47.200.128",
"kavlan-3": "192.168.226.36",
"kavlan-4": "10.16.2.36",
"kavlan-5": "10.16.66.36",
"kavlan-6": "10.16.130.36",
"kavlan-7": "10.16.194.36",
"kavlan-8": "10.17.2.36",
"kavlan-9": "10.17.66.36"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.36",
"kavlan": true,
"mac": "00:e0:81:d5:06:48",
"mountable": true,
"mounted": true,
"network_address": "graphene-36.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/35"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:49",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:4a",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:b9",
"ip": "172.18.64.36",
"ip6": "fe80::202:c903:b:92b9",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-36-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:92:ba",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.36",
"kavlan": false,
"mac": "00:e0:81:d5:06:4b",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-36-bmc.nancy.grid5000.fr",
"switch_port": "1/0/16"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu2"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-36"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": null
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.40",
"kavlan-11": "10.7.200.132",
"kavlan-12": "10.11.200.132",
"kavlan-13": "10.15.200.132",
"kavlan-14": "10.19.200.132",
"kavlan-16": "10.27.200.132",
"kavlan-18": "10.35.200.132",
"kavlan-19": "10.39.200.132",
"kavlan-2": "192.168.210.40",
"kavlan-20": "10.43.200.132",
"kavlan-21": "10.47.200.132",
"kavlan-3": "192.168.226.40",
"kavlan-4": "10.16.2.40",
"kavlan-5": "10.16.66.40",
"kavlan-6": "10.16.130.40",
"kavlan-7": "10.16.194.40",
"kavlan-8": "10.17.2.40",
"kavlan-9": "10.17.66.40"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.40",
"kavlan": true,
"mac": "00:e0:81:d5:06:f4",
"mountable": true,
"mounted": true,
"network_address": "graphene-40.nancy.grid5000.fr",
"rate": 1000000000,
"switch": "sgraphene2",
"switch_port": "GigabitEthernet1/0/1"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:f5",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:f6",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:93:cd",
"ip": "172.18.64.40",
"ip6": "fe80::202:c903:b:93cd",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-40-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:93:ce",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"kavlan": false,
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-40-bmc.nancy.grid5000.fr",
"switch": "sgraphene2-ipmi",
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu3"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-40"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": null
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.56",
"kavlan-11": "10.7.200.148",
"kavlan-12": "10.11.200.148",
"kavlan-13": "10.15.200.148",
"kavlan-14": "10.19.200.148",
"kavlan-16": "10.27.200.148",
"kavlan-18": "10.35.200.148",
"kavlan-19": "10.39.200.148",
"kavlan-2": "192.168.210.56",
"kavlan-20": "10.43.200.148",
"kavlan-21": "10.47.200.148",
"kavlan-3": "192.168.226.56",
"kavlan-4": "10.16.2.56",
"kavlan-5": "10.16.66.56",
"kavlan-6": "10.16.130.56",
"kavlan-7": "10.16.194.56",
"kavlan-8": "10.17.2.56",
"kavlan-9": "10.17.66.56"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.56",
"kavlan": true,
"mac": "00:e0:81:d5:06:78",
"mountable": true,
"mounted": true,
"network_address": "graphene-56.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/17"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:79",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:7a",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:91:89",
"ip": "172.18.64.56",
"ip6": "fe80::202:c903:b:9189",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-56-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:91:8a",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.56",
"kavlan": false,
"mac": "00:e0:81:d5:06:7b",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-56-bmc.nancy.grid5000.fr",
"switch_port": "1/0/1"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu4"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-56"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501"
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.83",
"kavlan-11": "10.7.200.175",
"kavlan-12": "10.11.200.175",
"kavlan-13": "10.15.200.175",
"kavlan-14": "10.19.200.175",
"kavlan-16": "10.27.200.175",
"kavlan-18": "10.35.200.175",
"kavlan-19": "10.39.200.175",
"kavlan-2": "192.168.210.83",
"kavlan-20": "10.43.200.175",
"kavlan-21": "10.47.200.175",
"kavlan-3": "192.168.226.83",
"kavlan-4": "10.16.2.83",
"kavlan-5": "10.16.66.83",
"kavlan-6": "10.16.130.83",
"kavlan-7": "10.16.194.83",
"kavlan-8": "10.17.2.83",
"kavlan-9": "10.17.66.83"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.83",
"kavlan": true,
"mac": "00:e0:81:d5:06:90",
"mountable": true,
"mounted": true,
"network_address": "graphene-83.nancy.grid5000.fr",
"rate": 1000000000,
"switch": "sgraphene3",
"switch_port": "GigabitEthernet1/0/10"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:06:91",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:06:92",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:93:a5",
"ip": "172.18.64.83",
"ip6": "fe80::202:c903:b:93a5",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-83-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:93:a6",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.83",
"kavlan": false,
"mac": "00:e0:81:d5:06:93",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-83-bmc.nancy.grid5000.fr",
"switch": "sgraphene3-ipmi",
"switch_port": "1/0/33"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu5"
"device": "sda",
"driver": "ahci",
"rev": "JPFOA3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-83"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 1009390096
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.94",
"kavlan-11": "10.7.200.186",
"kavlan-12": "10.11.200.186",
"kavlan-13": "10.15.200.186",
"kavlan-14": "10.19.200.186",
"kavlan-16": "10.27.200.186",
"kavlan-18": "10.35.200.186",
"kavlan-19": "10.39.200.186",
"kavlan-2": "192.168.210.94",
"kavlan-20": "10.43.200.186",
"kavlan-21": "10.47.200.186",
"kavlan-3": "192.168.226.94",
"kavlan-4": "10.16.2.94",
"kavlan-5": "10.16.66.94",
"kavlan-6": "10.16.130.94",
"kavlan-7": "10.16.194.94",
"kavlan-8": "10.17.2.94",
"kavlan-9": "10.17.66.94"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.94",
"ip6": "fe80::2e0:81ff:fed5:790",
"kavlan": true,
"mac": "00:e0:81:d5:07:90",
"mountable": true,
"mounted": true,
"network_address": "graphene-94.nancy.grid5000.fr",
"rate": 1000000000,
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:07:91",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:07:92",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:5c:95",
"ip": "172.18.64.94",
"ip6": "fe80::202:c903:b:5c95",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-94-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:5c:96",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.94",
"kavlan": false,
"mac": "00:e0:81:d5:07:93",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-94-bmc.nancy.grid5000.fr",
"switch_port": "1/0/10"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-94"
"architecture": {
"nb_cores": 4,
"nb_procs": 1,
"nb_threads": 4,
"bios": {
"version": "V7.01e"
"chassis": {
"name": "S5501",
"serial": 1009390100
"gpu": {
"gpu": false
"kavlan": {
"eth0": {
"kavlan-1": "192.168.194.98",
"kavlan-11": "10.7.200.190",
"kavlan-12": "10.11.200.190",
"kavlan-13": "10.15.200.190",
"kavlan-14": "10.19.200.190",
"kavlan-16": "10.27.200.190",
"kavlan-18": "10.35.200.190",
"kavlan-19": "10.39.200.190",
"kavlan-2": "192.168.210.98",
"kavlan-20": "10.43.200.190",
"kavlan-21": "10.47.200.190",
"kavlan-3": "192.168.226.98",
"kavlan-4": "10.16.2.98",
"kavlan-5": "10.16.66.98",
"kavlan-6": "10.16.130.98",
"kavlan-7": "10.16.194.98",
"kavlan-8": "10.17.2.98",
"kavlan-9": "10.17.66.98"
"main_memory": {
"monitoring": {
"bridged": true,
"device": "eth0",
"driver": "e1000e",
"enabled": true,
"ip": "172.16.64.98",
"ip6": "fe80::2e0:81ff:fed5:7d4",
"kavlan": true,
"mac": "00:e0:81:d5:07:d4",
"mountable": true,
"mounted": true,
"network_address": "graphene-98.nancy.grid5000.fr",
"rate": 1000000000,
"switch_port": "GigabitEthernet1/0/23"
"bridged": false,
"device": "eth1",
"driver": "e1000e",
"enabled": true,
"kavlan": false,
"mac": "00:e0:81:d5:07:d5",
"mountable": false,
"mounted": false,
"rate": 100000000
"bridged": false,
"device": "eth2",
"driver": "e1000e",
"enabled": false,
"kavlan": false,
"mac": "00:e0:81:d5:07:d6",
"mountable": false,
"mounted": false
"device": "ib0",
"enabled": true,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:5e:99",
"ip": "172.18.64.98",
"ip6": "fe80::202:c903:b:5e99",
"kavlan": false,
"mountable": true,
"mounted": true,
"network_address": "graphene-98-ib0.nancy.grid5000.fr",
"device": "ib1",
"enabled": false,
"guid": "20:00:55:00:41:80:00:00:00:00:00:00:00:02:c9:03:00:0b:5e:9a",
"kavlan": false,
"mountable": false,
"mounted": false,
"device": "bmc",
"enabled": true,
"ip": "172.17.64.98",
"kavlan": false,
"mac": "00:e0:81:d5:07:d7",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "graphene-98-bmc.nancy.grid5000.fr",
"switch_port": "1/0/14"
"cstate_max_id": 2,
"performance": {
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"ht_capable": true,
"vendor": "Intel",
"version": "X3440"
"sensors": {
"power": {
"available": true,
"via": {
"api": {
"metric": "power"
"pdu": [
"uid": "graphene-pdu6"
"device": "sda",
"driver": "ahci",
"rev": "A3EA",
"storage": "HDD",
"vendor": "Hitachi"
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "graphene-98"
This diff is collapsed.
......@@ -91,8 +91,3 @@ nodes:
sensors:
power:
available: true
graphene-96:
status: retired
graphene-86:
status: retired
nodes:
<% [123, 144, 1, 28, 36, 3, 40, 56, 83, 86, 94, 96, 98].each { |i| %>
graphene-<%= i %>:
status: retired
