Commit 416e31e3 authored by POUILLOUX Laurent's avatar POUILLOUX Laurent
Merge branch 'fix_wiki_walltime' into 'master'
[gen:wiki] fix node display in walltime for production cluster with retired nodes
See merge request !602
parents 7ece15a9 7c14ca24
1 merge request!602[gen:wiki] fix node display in walltime for production cluster with retired nodes
Pipeline #886900 passed with warnings
...@@ -165,7 +165,6 @@ class SiteHardwareGenerator < WikiGenerator ...@@ -165,7 +165,6 @@ class SiteHardwareGenerator < WikiGenerator
end end
def self.generate_description(site) def self.generate_description(site)
table_columns = []
text_data = [] text_data = []
hardware = get_hardware([site]) hardware = get_hardware([site])
...@@ -194,7 +193,6 @@ class SiteHardwareGenerator < WikiGenerator ...@@ -194,7 +193,6 @@ class SiteHardwareGenerator < WikiGenerator
access_conditions = [] access_conditions = []
access_conditions << queue_str if queue_str != '' access_conditions << queue_str if queue_str != ''
access_conditions << "exotic job type" if cluster_hash.map { |_k, v| v['exotic']}.first access_conditions << "exotic job type" if cluster_hash.map { |_k, v| v['exotic']}.first
table_columns = ['Cluster', 'Queue', 'Date of arrival', { attributes: 'data-sort-type="number"', text: 'Nodes' }, 'CPU', { attributes: 'data-sort-type="number"', text: 'Cores' }, { attributes: 'data-sort-type="number"', text: 'Memory' }, { attributes: 'data-sort-type="number"', text: 'Storage' }, { attributes: 'data-sort-type="number"', text: 'Network' }] + (site_accelerators.zero? ? [] : ['Accelerators'])
cluster_drawgantt_url = get_queue_drawgantt_url(site, queue)+"?filter=#{cluster_uid}%20only" cluster_drawgantt_url = get_queue_drawgantt_url(site, queue)+"?filter=#{cluster_uid}%20only"
text_data << ["\n== [#{cluster_drawgantt_url} #{cluster_uid}] ==\n"] text_data << ["\n== [#{cluster_drawgantt_url} #{cluster_uid}] ==\n"]
...@@ -225,21 +223,13 @@ class SiteHardwareGenerator < WikiGenerator ...@@ -225,21 +223,13 @@ class SiteHardwareGenerator < WikiGenerator
end end
# https://stackoverflow.com/questions/20847212/how-to-convert-an-array-of-number-into-ranges # https://stackoverflow.com/questions/20847212/how-to-convert-an-array-of-number-into-ranges
walltime_breakout.each { |walltime,allnodes| walltime_breakout.sort.each { |hours, allnodes|
prev_node = allnodes[0] prev = allnodes[0]
walltime_breakout[walltime] = allnodes.sort.slice_before { |node| range = allnodes.sort.slice_before { |node|
prev_node, node2 = node, prev_node prev, prev2 = node, prev
node2 + 1 != node prev2 + 1 != node}.map{|b,*,c| c ? "#{b}-#{c}" : b.to_s }
}.map{|b,*,c| c ? [b,c] : b }.flatten range_text = (range.length>1 or range[0].include? '-' ) ? "[#{range.join(',')}]" : range[0]
} walltime_breakout_text << "* #{cluster_uid}-#{range_text}: #{hours}h\n"
walltime_breakout.sort.each { |hours_range|
(hours, range) = hours_range
if range.length == 1
range_text = "#{range[0]}"
else
range_text = "[#{range[0]}-#{range[1]}]"
text_data << walltime_breakout_text text_data << walltime_breakout_text
end end
