Commit 40691596 authored by Pascal Morillon's avatar Pascal Morillon
[admin] fixes paradent-63
parent af93a09e
...@@ -3805,8 +3805,22 @@ paradent-63: ...@@ -3805,8 +3805,22 @@ paradent-63:
eth0: eth0:
mac: 00:e0:81:b2:c1:da mac: 00:e0:81:b2:c1:da
ip: 172.16.97.63 ip: 172.16.97.63
ip6: fe80::2e0:81ff:feb2:c1da
mounted: true
rate: 1000000000
management: false
enabled: true
interface: Ethernet
driver: e1000e
mountable: true
eth1: eth1:
mac: 00:e0:81:b2:c1:db mac: 00:e0:81:b2:c1:db
mounted: false
management: false
enabled: false
interface: Ethernet
driver: e1000e
mountable: false
operating_system: operating_system:
kernel: 2.6.32-5-amd64 kernel: 2.6.32-5-amd64
name: debian name: debian
