Commit 3aea8c62 authored by PAULIN Nathan's avatar PAULIN Nathan
[sophia][esterel11] add basic conf
parent 4c745d59
1 merge request!1257[sophia][esterel11] add to testing queue
"boot_type": "uefi", "boot_type": "bios",
"created_at": "Thu, 01 Jan 1970 00:00:00 GMT", "created_at": "Wed, 30 Apr 2025 00:00:00 GMT",
"exotic": false, "exotic": false,
"kavlan": false, "kavlan": false,
"manufactured_at": "1970-01-01", "manufactured_at": "1970-01-01",
...@@ -51,9 +51,9 @@ ...@@ -51,9 +51,9 @@
"model": "Cluster Model", "model": "Dell PowerEdge T630",
"nodes_count": 2, "nodes_count": 2,
"nodes_description": "1 CPU Unknown vendor, 72 cores/CPU, 0GB RAM, 0GB SSD, 1 x 10Gb Ethernet", "nodes_description": "1 CPU Unknown vendor, 72 cores/CPU, 0GB RAM, 2x0GB SSD, 1 x 1Gb Ethernet",
"priority": 197001, "priority": 197001,
"queues": [ "queues": [
"admin", "admin",
...@@ -23,7 +23,7 @@ ...@@ -23,7 +23,7 @@
"ram_size": 8 "ram_size": 8
"management_tools": { "management_tools": {
"bmc_vendor_tool": "ipmitool", "bmc_vendor_tool": "racadm",
"ipmitool": { "ipmitool": {
"retries": 5 "retries": 5
...@@ -50,9 +50,9 @@ ...@@ -50,9 +50,9 @@
"mounted": true, "mounted": true,
"name": "enp1s0f0np0", "name": "enp1s0f0np0",
"network_address": "esterel11-1.sophia.grid5000.fr", "network_address": "esterel11-1.sophia.grid5000.fr",
"rate": 10000000000, "rate": 1000000000,
"switch": null, "switch": "sw-5",
"switch_port": null "switch_port": "1/1/2"
"device": "bmc", "device": "bmc",
...@@ -77,8 +77,8 @@ ...@@ -77,8 +77,8 @@
"turboboost_enabled": true "turboboost_enabled": true
"performance": { "performance": {
"core_flops": 128, "core_flops": 33600000000,
"node_flops": 9216 "node_flops": 2419200000000
"processor": { "processor": {
"cache_l1": null, "cache_l1": null,
...@@ -86,10 +86,10 @@ ...@@ -86,10 +86,10 @@
"cache_l1i": 8, "cache_l1i": 8,
"cache_l2": 8, "cache_l2": 8,
"cache_l3": 8, "cache_l3": 8,
"clock_speed": 8, "clock_speed": 2100000000,
"ht_capable": true, "ht_capable": true,
"instruction_set": "x86-64", "instruction_set": "x86-64",
"microarchitecture": "Haswell", "microarchitecture": "Broadwell",
"microcode": "0xd000001", "microcode": "0xd000001",
"model": "Unknown", "model": "Unknown",
"other_description": "description", "other_description": "description",
...@@ -105,13 +105,23 @@ ...@@ -105,13 +105,23 @@
"storage_devices": [ "storage_devices": [
"by_id": "", "by_id": "",
"by_path": "/dev/disk/by-path/dummy", "by_path": "/dev/disk/by-path/pci-0000:03:00.0-scsi-0:2:0:0",
"id": "disk0", "id": "disk0",
"interface": "SAS", "interface": "SAS",
"model": "unknown", "model": "unknown",
"size": 8, "size": 8,
"storage": "SSD", "storage": "SSD",
"vendor": "Unknown" "vendor": "Unknown"
"by_id": "",
"by_path": "/dev/disk/by-path/pci-0000:03:00.0-scsi-0:2:1:0",
"id": "disk1",
"interface": "SATA",
"model": "unknown",
"size": 8,
"storage": "SSD",
"vendor": "Unknown"
"supported_job_types": { "supported_job_types": {
"network_address": "esterel11-2.sophia.grid5000.fr", "network_address": "esterel11-2.sophia.grid5000.fr",
"switch_port": null "switch_port": "1/1/3"
"by_id": "",
"id": "disk1",
"model": "unknown",
"size": 8,
"storage": "SSD",
"vendor": "Unknown"
...@@ -17,8 +17,16 @@ ...@@ -17,8 +17,16 @@
"uid": "esterel24-1" "uid": "esterel24-1"
"kind": "node",
"port": "eth0",
"snmp_name": "1/1/2",
"uid": "esterel11-1"
"kind": "node",
"port": "eth0",
"snmp_name": "1/1/3",
"uid": "esterel11-2"
...@@ -16,8 +16,14 @@ ...@@ -16,8 +16,14 @@
"uid": "esterel24-1-bmc" "uid": "esterel24-1-bmc"
"kind": "other",
"uid": "esterel11-1-bmc"
"kind": "other",
"uid": "esterel11-2-bmc"
model: Cluster Model # TODO: change this value. model: Dell PowerEdge T630
created_at: 1970-01-01 # TODO: change this value created_at: 2025-04-30
kavlan: false kavlan: false
boot_type: uefi # TODO: specify if 'uefi' (ideally) or 'bios' (legacy, if no other choice) boot_type: bios
exotic: false # TODO: specify if 'true' or 'false' exotic: false
queues: queues:
- admin - admin
- testing - testing
...@@ -17,8 +17,8 @@ nodes: ...@@ -17,8 +17,8 @@ nodes:
besteffort: true besteffort: true
max_walltime: 0 max_walltime: 0
processor: processor:
microarchitecture: Haswell # TODO: replace with microarch name. microarchitecture: Broadwell
clock_speed: 8 # TODO: Replace with clock speed. clock_speed: 2_100_000_000
network_adapters: network_adapters:
bmc: bmc:
interface: Ethernet interface: Ethernet
...@@ -33,9 +33,13 @@ nodes: ...@@ -33,9 +33,13 @@ nodes:
disk0: # This field will have to be renamed later. disk0: # This field will have to be renamed later.
id: disk0 id: disk0
interface: SAS interface: SAS
by_path: "/dev/disk/by-path/dummy" # this path will have to change later. by_path: "/dev/disk/by-path/pci-0000:03:00.0-scsi-0:2:0:0" # this path will have to change later.
disk1: # This field will have to be renamed later.
interface: SATA
by_path: "/dev/disk/by-path/pci-0000:03:00.0-scsi-0:2:1:0" # this path will have to change later.
software: software:
standard-environment: debian11-x64-std # TODO: check that architecture is OK standard-environment: debian11-x64-std
management_tools: management_tools:
bmc_vendor_tool: ipmitool # TODO: replace with bmc_vendor_tool (ipmitool, racadm) bmc_vendor_tool: racadm
nodeset: esterel11 nodeset: esterel11
...@@ -72,11 +72,15 @@ nodes: ...@@ -72,11 +72,15 @@ nodes:
management: false management: false
driver: mlx_core # Fake data, will be replaced by g5k-checks driver: mlx_core # Fake data, will be replaced by g5k-checks
name: enp1s0f0np0 # Fake data, will be replaced by g5k-checks name: enp1s0f0np0 # Fake data, will be replaced by g5k-checks
rate: 10000000000 # Fake data, will be replaced by g5k-checks rate: 1000000000 # Fake data, will be replaced by g5k-checks
mac: <%= mac_eth0_list[i - 1] %> mac: <%= mac_eth0_list[i - 1] %>
storage_devices: storage_devices:
disk0: disk0:
storage: SSD # Fake data, will be replaced by g5k-checks storage: SSD # Fake data, will be replaced by g5k-checks
model: unknown # Fake data, will be replaced by g5k-checks model: unknown # Fake data, will be replaced by g5k-checks
size: 8 # Fake data, will be replaced by g5k-checks size: 8 # Fake data, will be replaced by g5k-checks
disk1:
...@@ -16,6 +16,10 @@ sw-5: ...@@ -16,6 +16,10 @@ sw-5:
ports: ports:
1: 1:
uid: esterel24-1 uid: esterel24-1
2:
uid: esterel11-1
3:
uid: esterel11-2
25: 25:
uid: gw uid: gw
kind: router kind: router
...@@ -17,6 +17,12 @@ swadmin-5: ...@@ -17,6 +17,12 @@ swadmin-5:
1: 1:
uid: esterel24-1-bmc uid: esterel24-1-bmc
kind: other kind: other
2:
uid: esterel11-1-bmc
kind: other
3:
uid: esterel11-2-bmc
kind: other
25: 25:
uid: sw-5 uid: sw-5
kind: switch kind: switch
