GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
2b609a44
2b609a44
3 years ago
Samir Noir
Downloads
Patches
[lib] handle new memory_devices in nodes' description
41853108
2
2 changed files
lib/refrepo/gen/reference-api.rb
+8
8 additions, 0 deletions
lib/refrepo/valid/input/schemas/schema-node.yaml
+5
5 additions, 0 deletions
13 additions
8
2b609a44
@@ -136,6 +136,14 @@ def generate_reference_api
node
"network_adapters"
each
key
hash
node
"network_adapters"
key
"device"
key
# Add "device: ethX" within the hash
node
"network_adapters"
each
key
hash
node
"network_adapters"
key
"device"
key
node
"network_adapters"
node
"network_adapters"
sort_by_array
"eth0"
"eth1"
"eth2"
"eth3"
"eth4"
"eth5"
"eth6"
"ib0.8100"
"ib0"
"ib1"
"ib2"
"ib3"
"ibs1"
"bmc"
"eno1"
"eno2"
"eno1np0"
"eno2np1"
"ens4f0"
"ens4f1"
"ens5f0"
"ens5f1"
values
node
"network_adapters"
node
"network_adapters"
sort_by_array
"eth0"
"eth1"
"eth2"
"eth3"
"eth4"
"eth5"
"eth6"
"ib0.8100"
"ib0"
"ib1"
"ib2"
"ib3"
"ibs1"
"bmc"
"eno1"
"eno2"
"eno1np0"
"eno2np1"
"ens4f0"
"ens4f1"
"ens5f0"
"ens5f1"
values
node
"memory_devices"
each
key
hash
node
"memory_devices"
key
"device"
key
# Add "device: dimm_a1" within the hash
node
"memory_devices"
node
"memory_devices"
sort_by
d
_
d
gsub
/dimm_(\d+)/
'\1'
to_i
d
gsub
/^dimm_([A-z]+)(\d+)$/
'\1'
d
gsub
'\2'
to_i
to_h
node
"memory_devices"
node
"memory_devices"
values
write_json
cluster_path
join
"nodes"
node_uid
.json"
node
write_json
cluster_path
join
"nodes"
node_uid
.json"
node
This diff is collapsed.
5
2b609a44
@@ -33,6 +33,11 @@ kavlan6:
main_memory
main_memory
ram_size
integer
ram_size
integer
pmem_size
optional_integer
pmem_size
optional_integer
memory_devices
<multi>
size
integer
technology
string
firmware
optional_string
mic
optional_hash
mic
optional_hash
network_adapters
network_adapters
<multi>
<multi>
Loading
Save comment
