Commit 2b431a8b authored by Jérémie Gaidamour's avatar Jérémie Gaidamour
[lyon] Updated hercule
parent b933a5ac
...@@ -14,8 +14,11 @@ ...@@ -14,8 +14,11 @@
"name": "PowerEdge C6220", "name": "PowerEdge C6220",
"serial": "JQ3HD5J" "serial": "JQ3HD5J"
"gpu": {
"gpu": false
"main_memory": { "main_memory": {
"ram_size": 34359738368, "ram_size": 33285996544,
"virtual_size": null "virtual_size": null
"monitoring": { "monitoring": {
"serial": "HQ3HD5J" "serial": "HQ3HD5J"
"gpu": {
"gpu": false
"serial": "FQ3HD5J" "serial": "FQ3HD5J"
"gpu": {
"gpu": false
"serial": "GQ3HD5J" "serial": "GQ3HD5J"
"gpu": {
"gpu": false
...@@ -120,13 +120,14 @@ global_hash["sites"].each do |site_uid, site| ...@@ -120,13 +120,14 @@ global_hash["sites"].each do |site_uid, site|
network_adapter["switch"], network_adapter["switch_port"] = net_switch_port_lookup(site, node_uid, network_adapter["device"]) || net_switch_port_lookup(site, node_uid) network_adapter["switch"], network_adapter["switch_port"] = net_switch_port_lookup(site, node_uid, network_adapter["device"]) || net_switch_port_lookup(site, node_uid)
else else
# Secondary network_adapter(s) # Secondary network_adapter(s)
network_adapter["network_address"] = "#{node_uid}-#{network_adapter["device"]}.#{site_uid}.grid5000.fr" if network_adapter["enabled"] && network_adapter["mountable"] network_adapter["network_address"] = "#{node_uid}-#{network_adapter["device"]}.#{site_uid}.grid5000.fr" if network_adapter["enabled"] && network_adapter["mountable"] && !network_adapter.key?("network_address")
if network_adapter["mountable"] if network_adapter["mountable"]
switch, port = net_switch_port_lookup(site, node_uid, network_adapter["device"]) switch, port = net_switch_port_lookup(site, node_uid, network_adapter["device"])
network_adapter["switch"] = switch if switch network_adapter["switch"] = switch if switch
network_adapter["switch_port"] = port if port network_adapter["switch_port"] = port if port
end end
end end
network_adapter.delete("network_address") if network_adapter["network_address"] == 'none'
node["sensors"] ||= {} node["sensors"] ||= {}
