Commit 28ef8081 authored by DELABROYE Dimitri's avatar DELABROYE Dimitri
[lille] fix bad indentation
parent 5037d415
"kind": "physical", "kind": "physical",
"monitoring": {
"metric": "power",
"wattmeter": "multiple"
"network_adapters": { "network_adapters": {
"bmc": { "bmc": {
"ip": "172.17.46.9", "ip": "172.17.46.9",
...@@ -10,10 +14,6 @@ ...@@ -10,10 +14,6 @@
"ip": "172.16.47.9", "ip": "172.16.47.9",
"mac": "24:6E:96:DC:F4:2C", "mac": "24:6E:96:DC:F4:2C",
"mounted": true "mounted": true
"monitoring": {
"metric": "power",
"sensors": { "sensors": {
"monitoring": {
"metric": "power",
"bmc": { "bmc": {
"ip": "172.17.46.14", "ip": "172.17.46.14",
"ip": "172.16.47.14", "ip": "172.16.47.14",
"mac": "3C:FD:FE:B9:91:30", "mac": "3C:FD:FE:B9:91:30",
"monitoring": {
"metric": "power",
"monitoring": {
"metric": "power",
"bmc": { "bmc": {
"ip": "172.17.46.15", "ip": "172.17.46.15",
"ip": "172.16.47.15", "ip": "172.16.47.15",
"mac": "3C:FD:FE:B9:9A:10", "mac": "3C:FD:FE:B9:9A:10",
"monitoring": {
"metric": "power",
"monitoring": {
"metric": "power",
"bmc": { "bmc": {
"ip": "172.17.46.4", "ip": "172.17.46.4",
"ip": "172.16.47.4", "ip": "172.16.47.4",
"mac": "24:6E:96:DD:1F:56", "mac": "24:6E:96:DD:1F:56",
"monitoring": {
"metric": "power",
...@@ -274,9 +274,9 @@ gardin: ...@@ -274,9 +274,9 @@ gardin:
mounted: true mounted: true
ip: 172.17.46.9 ip: 172.17.46.9
mac: 54:48:10:f4:f9:0c mac: 54:48:10:f4:f9:0c
monitoring: monitoring:
wattmeter: multiple wattmeter: multiple
metric: power metric: power
sensors: sensors:
network: network:
available: true available: true
...@@ -304,9 +304,9 @@ gwol-north: ...@@ -304,9 +304,9 @@ gwol-north:
ip: 172.17.46.4 ip: 172.17.46.4
mac: 54:48:10:f4:f5:ca mac: 54:48:10:f4:f5:ca
sensors: sensors:
network: network:
...@@ -334,9 +334,9 @@ granche-srv1: ...@@ -334,9 +334,9 @@ granche-srv1:
ip: 172.17.46.14 ip: 172.17.46.14
mac: 54:48:10:f2:e9:78 mac: 54:48:10:f2:e9:78
sensors: sensors:
network: network:
...@@ -364,9 +364,9 @@ granche-srv2: ...@@ -364,9 +364,9 @@ granche-srv2:
ip: 172.17.46.15 ip: 172.17.46.15
mac: 54:48:10:f2:d3:7c mac: 54:48:10:f2:d3:7c
sensors: sensors:
network: network:
