Commit 28d2d77e authored by Ludovic Schoepps's avatar Ludovic Schoepps
[luxembourg][vianden] Add vianden cluster
parent f26bf42f
"architecture": {
"cpu_core_numbering": "contiguous",
"nb_cores": 72,
"nb_procs": 1,
"nb_threads": 72,
"platform_type": "x86_64"
"bios": {
"release_date": "01/01/2000",
"vendor": "Unknown",
"version": 1
"bmc_version": "v1",
"chassis": {
"manufactured_at": "2024-07-14",
"manufacturer": "Unknown",
"name": "Unknown",
"warranty_end": "2028-07-15"
"exotic": false,
"main_memory": {
"ram_size": 8
"management_tools": {
"bmc_vendor_tool": "racadm",
"ipmitool": {
"retries": 5
"memory_devices": [
"device": "dimm_proc 1 dimm 1",
"size": 8,
"technology": "dram"
"network_adapters": [
"device": "eth0",
"driver": "mlx_core",
"enabled": true,
"interface": "Ethernet",
"ip": "172.16.178.1",
"ip6": "2001:660:4406:300:3::1",
"kavlan": false,
"mac": "c4:cb:e1:c8:54:06",
"management": false,
"mountable": true,
"mounted": true,
"name": "enp1s0f0np0",
"network_address": "vianden-1.luxembourg.grid5000.fr",
"rate": 10000000000,
"switch": null,
"switch_port": null
"device": "bmc",
"enabled": true,
"ip": "172.17.178.1",
"kavlan": false,
"mac": "c4:cb:e1:c5:f2:4a",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "vianden-1-bmc.luxembourg.grid5000.fr"
"nodeset": "vianden",
"operating_system": {
"cstate_driver": "unknown",
"cstate_governor": "unknown",
"ht_enabled": true,
"pstate_driver": "unknwon",
"pstate_governor": "unknown",
"turboboost_enabled": true
"performance": {
"core_flops": 121600000000,
"node_flops": 8755200000000
"processor": {
"cache_l1": null,
"cache_l1d": 8,
"cache_l1i": 8,
"cache_l2": 8,
"cache_l3": 8,
"clock_speed": 3800000000,
"ht_capable": true,
"instruction_set": "x86-64",
"microarchitecture": "Sapphire Rapids",
"microcode": "0xd000001",
"model": "Unknown",
"other_description": "description",
"vendor": "vendor",
"version": "vendor"
"redfish": true,
"software": {
"forced-deployment-timestamp": 202007300948,
"postinstall-version": "1.2024112508",
"standard-environment": "debian11-x64-std"
"storage_devices": [
"by_id": "",
"by_path": "/dev/disk/by-path/dummy",
"id": "disk0",
"interface": "SAS",
"model": "unknown",
"size": 8,
"storage": "SSD",
"vendor": "Unknown"
"supported_job_types": {
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"admin",
"testing"
"type": "node",
"uid": "vianden-1"
\ No newline at end of file
"boot_type": "uefi",
"created_at": "Mon, 06 Jan 2025 00:00:00 GMT",
"exotic": false,
"kavlan": false,
"metrics": [
"model": "Dell PowerEdge XE9680",
"queues": [
"admin",
"testing"
"redfish": true,
"type": "cluster",
"uid": "vianden",
...@@ -31,6 +31,7 @@ ipv4: ...@@ -31,6 +31,7 @@ ipv4:
lille chuc eth1 0 0 0 100 lille chuc eth1 0 0 0 100
luxembourg petitprince eth0 0 0 1 0 luxembourg petitprince eth0 0 0 1 0
luxembourg petitprince eth1 0 0 1 100 luxembourg petitprince eth1 0 0 1 100
luxembourg vianden eth0 0 0 2 0
lyon sagittaire eth1 0 0 1 0 lyon sagittaire eth1 0 0 1 0
lyon taurus eth0 0 0 0 0 lyon taurus eth0 0 0 0 0
lyon orion eth0 0 0 2 0 lyon orion eth0 0 0 2 0
vianden-1:
architecture:
nb_procs: 1
nb_cores: 72
nb_threads: 72
platform_type: x86_64
cpu_core_numbering: contiguous
bios:
release_date: 01/01/2000 # Fake date, will be replaced by g5k-checks
vendor: Unknown # Fake vendor, will be replaced by g5k-checks
version: 1 # Fake version, will be replaced by g5k-checks
bmc_version: v1 # Fake version, will be replaced by g5k-checks
chassis:
manufacturer: Unknown # Fake manufacturer, will be replaced by g5k-checks
name: Unknown # Fake name, will be replaced by g5k-checks
main_memory:
ram_size: 8 # Fake size, will be replaced by g5k-checks
memory_devices:
dimm:
technology: dram # Common memory technology, will be replaced by g5k-checks
processor:
model: Unknown # Fake model name, will be replaced by g5k-checks
other_description: description # Fake description, will be replaced by g5k-checks
vendor: vendor # Fake vendor, will be replaced by g5k-checks
version: vendor # Fake version, will be replaced by g5k-checks
cache_l1d: 8 # Fake cache, will be replaced by g5k-checks
cache_l1i: 8 # Fake cache, will be replaced by g5k-checks
cache_l2: 8 # Fake cache, will be replaced by g5k-checks
cache_l3: 8 # Fake cache, will be replaced by g5k-checks
instruction_set: x86-64 # Common instruction set, will be replaced by g5k-checks
microcode: "0xd000001" # Fake microcode, will be replaced by g5k-checks
ht_capable: true # Default ht capable value, will be replaced by g5k-checks
main_memory:
ram_size: 8 # Fake ram size, will be replaced by g5k-checks
memory_devices:
dimm_proc 1 dimm 1: # Fake dimm name, will be replaced by g5k-checks
size: 8 # Fake dimm size, will be replaced by g5k-checks
technology: dram # Default dimm technology, will be replaced by g5k-checks
operating_system:
cstate_driver: unknown # Fake driver, will be replaced by g5k-checks
cstate_governor: unknown # Fake governor, will be replaced by g5k-checks
ht_enabled: true # common value for hyper threading, will be replaced by g5k-checks
pstate_driver: unknwon # Fake driver, will be replaced by g5k-checks
pstate_governor: unknown # Fake driver, will be replaced by g5k-checks
turboboost_enabled: true # Default value for turboboost, will be replaced by g5k-checks
network_adapters:
bmc:
interface: Ethernet
management: true
mac: c4:cb:e1:c5:f2:4a
ip: 172.17.178.1
eth0:
interface: Ethernet
management: false
driver: mlx_core
rate: 10000000000
mac: c4:cb:e1:c8:54:06
ip: 172.16.178.1
storage_devices:
disk0:
storage: SSD # Common value, will be replaced by g5k-checks
model: unknown # fake value,
size: 8 # Fake value, will be replaced by g5k-checks
model: Dell PowerEdge XE9680
created_at: 2025-01-06
kavlan: false
boot_type: uefi
exotic: false # TODO: specify if 'true' or 'false'
queues:
- admin
- testing
nodes:
vianden-1:
chassis:
manufactured_at: 2024-07-14
warranty_end: 2028-07-15
supported_job_types:
deploy: true
besteffort: true
max_walltime: 0
processor:
microarchitecture: Sapphire Rapids
clock_speed: 3_800_000_000
network_adapters:
bmc:
enabled: true
mountable: false
mounted: false
eth0:
enabled: true
mountable: true
mounted: true
storage_devices:
disk0: # This field will have to be renamed later.
interface: SAS
by_path: "/dev/disk/by-path/dummy" # this path will have to change later.
software:
standard-environment: debian11-x64-std
management_tools:
bmc_vendor_tool: racadm
nodeset: vianden
...@@ -730,7 +730,7 @@ def get_flops_per_cycle(microarch, cpu_name, cluster_uid) ...@@ -730,7 +730,7 @@ def get_flops_per_cycle(microarch, cpu_name, cluster_uid)
# FIXME: Find Jetson's FlopPerCycle # FIXME: Find Jetson's FlopPerCycle
when /Carmel/ when /Carmel/
return 8 return 8
when "Golden Cove" when "Golden Cove", "Sapphire Rapids"
return 32 return 32
end end
raise "Error: Unknown CPU architecture for cluster #{cluster_uid}, cannot compute flops" raise "Error: Unknown CPU architecture for cluster #{cluster_uid}, cannot compute flops"
