GitLab
Explore
Primary navigation
Search or go to…
R
reference-repository
Manage
Plan
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
grid5000
27d6393e
27d6393e
3 years ago
RINGOT Patrice
Downloads
Patches
[gpumem] wip
df3196de
Pipeline
#305861
failed
3 years ago
Stage: validate
Stage: generate
Stage: deploy
lib/refrepo/gen/oar-properties.rb
+7
7 additions, 0 deletions
7 additions
7
27d6393e
@@ -10,6 +10,7 @@ require 'refrepo/gpu_ref'
class
MissingProperty
StandardError
class
MissingProperty
StandardError
MiB
1024
2
MiB
1024
2
GiB
1024
3
# Functions related to the "TABLE" operation
@@ -247,6 +248,7 @@ def export_rows_as_oar_command(generated_hierarchy, site_name, site_properties,
gpudevice
oar_ressource_row
:gpudevice
to_s
gpudevice
oar_ressource_row
:gpudevice
to_s
gpumodel
oar_ressource_row
:gpumodel
to_s
gpumodel
oar_ressource_row
:gpumodel
to_s
gpudevicepath
oar_ressource_row
:gpudevicepath
to_s
gpudevicepath
oar_ressource_row
:gpudevicepath
to_s
memgpu
oar_ressource_row
:memgpu
to_i
resource_id
oar_ressource_row
:resource_id
resource_id
oar_ressource_row
:resource_id
if
resource_id
resource_id
nil?
if
resource_id
resource_id
nil?
@@ -433,9 +435,11 @@ def get_ref_node_properties_internal(cluster_uid, cluster, node_uid, node)
h
'gpu_model'
models
first
h
'gpu_model'
models
first
h
'gpu_count'
node
'gpu_devices'
length
h
'gpu_count'
node
'gpu_devices'
length
h
'memgpu'
models
first
'memory'
GiB
else
else
h
'gpu_model'
h
'gpu_model'
h
'gpu_count'
h
'gpu_count'
h
'memgpu'
if
node
key?
'exotic'
if
node
key?
'exotic'
@@ -705,6 +709,7 @@ def ignore_default_keys()
"host"
# This property was created by 'oar_resources_add'
"host"
"gpudevice"
# New property taken into account by the new generator
"gpudevice"
"gpu"
"gpu"
"memgpu"
"cpuset"
"cpuset"
"desktop_computing"
"desktop_computing"
"drain"
"drain"
@@ -1300,6 +1305,7 @@ def extract_clusters_description(clusters, site_name, options, data_hierarchy, s
:cpuset
nil
:cpuset
nil
:gpu
nil
:gpu
nil
:gpudevice
nil
:gpudevice
nil
:memgpu
nil
:gpudevicepath
nil
:gpudevicepath
nil
:cpumodel
nil
:cpumodel
nil
:gpumodel
nil
:gpumodel
nil
@@ -1358,6 +1364,7 @@ def extract_clusters_description(clusters, site_name, options, data_hierarchy, s
row
:gpudevice
local_id
row
:gpudevice
local_id
row
:gpudevicepath
selected_gpu
'device'
row
:gpudevicepath
selected_gpu
'device'
row
:gpumodel
selected_gpu
'model'
row
:gpumodel
selected_gpu
'model'
row
:memgpu
selected_gpu
'memory'
This diff is collapsed.
Loading
Save comment
