Commit 19ff1429 authored by Benjamin's avatar Benjamin
[sophia/uvb] uvb-8 is retired
parent 15f05a99
1 merge request!275[sophia/uvb] uvb-8 is retired
Pipeline #278379 passed
"architecture": {
"cpu_core_numbering": "contiguous",
"nb_cores": 12,
"nb_procs": 2,
"nb_threads": 24,
"platform_type": "x86_64"
"bios": {
"release_date": "09/17/2013",
"vendor": "Dell Inc.",
"version": 1.71
"bmc_version": "1.33",
"chassis": {
"manufacturer": "Dell",
"name": "C6100",
"serial": "857XY4J"
"exotic": false,
"kavlan": {
"eth0": {
"kavlan-1": "192.168.193.8",
"kavlan-11": "10.7.232.8",
"kavlan-12": "10.11.232.8",
"kavlan-13": "10.15.232.8",
"kavlan-14": "10.19.232.8",
"kavlan-16": "10.27.232.8",
"kavlan-18": "10.35.232.8",
"kavlan-2": "192.168.209.8",
"kavlan-20": "10.43.232.8",
"kavlan-21": "10.47.232.8",
"kavlan-3": "192.168.225.8",
"kavlan-4": "10.32.1.8",
"kavlan-5": "10.32.65.8",
"kavlan-6": "10.32.129.8",
"kavlan-7": "10.32.193.8",
"kavlan-8": "10.33.1.8",
"kavlan-9": "10.33.65.8"
"kavlan6": {
"eth0": {
"kavlan-1": "2001:660:4406:880:5::8",
"kavlan-11": "2001:660:4406:1a0:805::8",
"kavlan-12": "2001:660:4406:2a0:805::8",
"kavlan-13": "2001:660:4406:4a0:805::8",
"kavlan-14": "2001:660:4406:5a0:805::8",
"kavlan-16": "2001:660:4406:7a0:805::8",
"kavlan-18": "2001:660:4406:8a0:805::8",
"kavlan-2": "2001:660:4406:881:5::8",
"kavlan-20": "2001:660:4406:3a0:805::8",
"kavlan-21": "2001:660:4406:6a0:805::8",
"kavlan-3": "2001:660:4406:882:5::8",
"kavlan-4": "2001:660:4406:890:5::8",
"kavlan-5": "2001:660:4406:891:5::8",
"kavlan-6": "2001:660:4406:892:5::8",
"kavlan-7": "2001:660:4406:893:5::8",
"kavlan-8": "2001:660:4406:894:5::8",
"kavlan-9": "2001:660:4406:895:5::8"
"main_memory": {
"ram_size": 103079215104
"network_adapters": [
"bridged": true,
"device": "eth0",
"driver": "igb",
"enabled": true,
"firmware_version": "1.4.3",
"interface": "Ethernet",
"ip": "172.16.132.8",
"ip6": "2001:660:4406:800:5::8",
"kavlan": true,
"mac": "00:26:6c:f8:3a:14",
"management": false,
"model": "82576 Gigabit Network Connection",
"mountable": true,
"mounted": true,
"name": "eno1",
"network_address": "uvb-8.sophia.grid5000.fr",
"rate": 1000000000,
"sriov": true,
"sriov_totalvfs": 7,
"switch": "gw",
"switch_port": "GigabitEthernet4/24",
"vendor": "Intel"
"device": "eth1",
"driver": "igb",
"enabled": false,
"kavlan": false,
"mac": "00:26:6c:f8:3a:15",
"mountable": false,
"mounted": false,
"name": "eno2",
"sriov": true,
"vendor": "Intel"
"device": "ib0",
"driver": "mlx4_core",
"enabled": true,
"firmware_version": "2.9.1000",
"guid": "0x0024e89097ffc669",
"interface": "InfiniBand",
"ip": "172.18.132.8",
"kavlan": false,
"mac": "00:24:e8:90:97:ff:c6:69",
"model": "MT26428 [ConnectX VPI PCIe 2.0 5GT/s - IB QDR / 10GigE]",
"mountable": true,
"mounted": true,
"name": "ib0",
"netmask": "255.255.240.0",
"network_address": "uvb-8-ib0.sophia.grid5000.fr",
"rate": 40000000000,
"vendor": "Mellanox Technologies"
"device": "ib1",
"enabled": false,
"guid": "0x0024e89097ffc66a",
"kavlan": false,
"mac": "00:24:e8:90:97:ff:c6:6a",
"mountable": false,
"mounted": false,
"name": "ib1",
"rate": 10000000000,
"device": "bmc",
"enabled": true,
"ip": "172.17.132.8",
"kavlan": false,
"mac": "00:26:6c:f8:3a:16",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "uvb-8-bmc.sophia.grid5000.fr"
"operating_system": {
"cstate_driver": "intel_idle",
"cstate_governor": "menu",
"ht_enabled": true,
"pstate_driver": "none",
"pstate_governor": "none",
"turboboost_enabled": false
"performance": {
"core_flops": 11800000000,
"node_flops": 141600000000
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 262144,
"cache_l3": 12582912,
"clock_speed": 2950000000,
"ht_capable": true,
"instruction_set": "x86-64",
"microarchitecture": "Westmere",
"microcode": "0x1f",
"model": "Intel Xeon",
"other_description": "Intel(R) Xeon(R) CPU X5670 @ 2.93GHz",
"vendor": "Intel",
"version": "X5670"
"software": {
"forced-deployment-timestamp": 202007300948,
"postinstall-version": "1.2021070100",
"standard-environment": "debian10-x64-std"
"storage_devices": [
"by_id": "/dev/disk/by-id/wwn-0x50014ee1037d9480",
"by_path": "/dev/disk/by-path/pci-0000:00:1f.2-ata-1",
"device": "sda",
"firmware_version": "02.03B05",
"id": "disk0",
"interface": "SATA",
"model": "WDC WD2502ABYS-1",
"size": 250000000000,
"storage": "HDD",
"vendor": "Western Digital"
"supported_job_types": {
"besteffort": true,
"deploy": true,
"max_walltime": 0,
"queues": [
"default",
"admin"
"virtual": "ivt"
"type": "node",
"uid": "uvb-8"
\ No newline at end of file
...@@ -256,14 +256,6 @@ ...@@ -256,14 +256,6 @@
"port": "eth0", "port": "eth0",
"snmp_name": "GigabitEthernet4/22", "snmp_name": "GigabitEthernet4/22",
"uid": "uvb-7" "uid": "uvb-7"
"kind": "node",
"port": "eth0",
"snmp_name": "GigabitEthernet4/24",
"uid": "uvb-8"
"rate": 1000000000, "rate": 1000000000,
# Generated by g5k-checks (g5k-checks -m api)
uvb-8:
architecture:
cpu_core_numbering: contiguous
nb_cores: 12
nb_procs: 2
nb_threads: 24
platform_type: x86_64
bios:
release_date: '09/17/2013'
vendor: Dell Inc.
version: 1.71
bmc_version: '1.33'
chassis:
manufacturer: Dell
serial: 857XY4J
main_memory:
ram_size: 103079215104
network_adapters:
bmc:
ip: 172.17.132.8
mac: 00:26:6c:f8:3a:16
management: true
eth0:
driver: igb
firmware_version: 1.4.3
interface: Ethernet
ip: 172.16.132.8
mac: 00:26:6c:f8:3a:14
management: false
model: 82576 Gigabit Network Connection
rate: 1000000000
sriov: true
sriov_totalvfs: 7
vendor: Intel
eth1:
driver: igb
interface: Ethernet
mac: 00:26:6c:f8:3a:15
management: false
sriov: true
sriov_totalvfs: 7
vendor: Intel
ib0:
driver: mlx4_core
firmware_version: 2.9.1000
guid: '0x0024e89097ffc669'
interface: InfiniBand
ip: 172.18.132.8
mac: 00:24:e8:90:97:ff:c6:69
management: false
model: MT26428 [ConnectX VPI PCIe 2.0 5GT/s - IB QDR / 10GigE]
rate: 40000000000
vendor: Mellanox Technologies
ib1:
driver: mlx4_core
guid: '0x0024e89097ffc66a'
mac: 00:24:e8:90:97:ff:c6:6a
management: false
rate: 10000000000
operating_system:
cstate_driver: intel_idle
cstate_governor: menu
ht_enabled: true
pstate_driver: none
pstate_governor: none
turboboost_enabled: false
processor:
cache_l1d: 32768
cache_l1i: 32768
cache_l2: 262144
cache_l3: 12582912
ht_capable: true
instruction_set: x86-64
microcode: '0x1f'
model: Intel Xeon
other_description: Intel(R) Xeon(R) CPU X5670 @ 2.93GHz
vendor: Intel
version: X5670
storage_devices:
sda:
by_id: "/dev/disk/by-id/wwn-0x50014ee1037d9480"
by_path: "/dev/disk/by-path/pci-0000:00:1f.2-ata-1"
firmware_version: 02.03B05
model: WDC WD2502ABYS-1
storage: HDD
supported_job_types:
virtual: ivt
nodes: nodes:
<% [3, 13, 15, 19, 20, 21, 22, 23, 24, 30, 32, 39, 40].each do |i| %> <% [3, 8, 13, 15, 19, 20, 21, 22, 23, 24, 30, 32, 39, 40].each do |i| %>
uvb-<%= i %>: uvb-<%= i %>:
status: retired status: retired
<% end %> <% end %>
...@@ -184,7 +184,6 @@ gw: ...@@ -184,7 +184,6 @@ gw:
18: uvb-5 18: uvb-5
20: uvb-6 20: uvb-6
22: uvb-7 22: uvb-7
24: uvb-8
7: 7:
snmp_pattern: "GigabitEthernet%LINECARD%/%PORT%" snmp_pattern: "GigabitEthernet%LINECARD%/%PORT%"
kavlan_pattern: "%LINECARD%/%PORT%" kavlan_pattern: "%LINECARD%/%PORT%"
