Commit 05c375f7 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[drac] really set the correct rate on all interfaces
parent ab6e7778
Pipeline #184547 passed
with 12 additions and 20 deletions
......@@ -87,7 +87,6 @@
"mounted": true,
"name": "enP1p1s0f3",
"network_address": "drac-1.grenoble.grid5000.fr",
"rate": 1000000000,
"switch": null,
"switch_port": null,
"vendor": "Broadcom"
......@@ -37,7 +37,7 @@
"mountable": false,
"mounted": false,
"name": "enP1p1s0f0",
"rate": 1000000000,
"rate": 10000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mounted": true,
"network_address": "drac-2.grenoble.grid5000.fr",
"rate": 1000000000,
"switch": null,
"mounted": true,
"network_address": "drac-3.grenoble.grid5000.fr",
"rate": 1000000000,
"switch": null,
"mounted": true,
"network_address": "drac-4.grenoble.grid5000.fr",
"rate": 1000000000,
"switch": null,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
"mountable": false,
"mounted": false,
"rate": 1000000000,
......@@ -59,7 +59,6 @@ drac-1:
management: false
model: NetXtreme II BCM57800 1/10 Gigabit Ethernet
rate: 1000000000
vendor: Broadcom
eth4:
driver: tg3
......@@ -30,7 +30,7 @@ drac-10:
management: false
rate: 1000000000
rate: 10000000000
vendor: Broadcom
eth1:
driver: bnx2x
......@@ -30,7 +30,7 @@ drac-11:
management: false
rate: 1000000000
rate: 10000000000
vendor: Broadcom
eth1:
driver: bnx2x
......@@ -30,7 +30,7 @@ drac-12:
management: false
rate: 1000000000
rate: 10000000000
vendor: Broadcom
eth1:
driver: bnx2x
......@@ -59,7 +59,6 @@ drac-2:
management: false
rate: 1000000000
vendor: Broadcom
eth4:
driver: tg3
......@@ -59,7 +59,6 @@ drac-3:
management: false
rate: 1000000000
vendor: Broadcom
eth4:
driver: tg3
......@@ -59,7 +59,6 @@ drac-4:
management: false
rate: 1000000000
vendor: Broadcom
eth4:
driver: tg3
......@@ -30,7 +30,7 @@ drac-5:
management: false
rate: 1000000000
rate: 10000000000
vendor: Broadcom
eth1:
driver: bnx2x
