Commit 039a55d1 authored by PAULIN Nathan's avatar PAULIN Nathan
[nancy][grvingt] grvingt-33 retirement
parent 545263bd
Pipeline #1095516 passed
"architecture": {
"cpu_core_numbering": "round-robin",
"nb_cores": 32,
"nb_procs": 2,
"nb_threads": 64,
"platform_type": "x86_64"
"bios": {
"release_date": "06/12/2023",
"vendor": "Dell Inc.",
"version": "2.19.1"
"bmc_version": "6.10.80.00",
"chassis": {
"manufactured_at": "2018-04-10",
"manufacturer": "Dell Inc.",
"name": "PowerEdge C6420",
"serial": "CP48DP2",
"warranty_end": "2023-04-10"
"exotic": false,
"kavlan": {
"eth0": {
"kavlan-1": "192.168.195.33",
"kavlan-11": "10.7.216.33",
"kavlan-12": "10.11.216.33",
"kavlan-13": "10.15.216.33",
"kavlan-14": "10.19.216.33",
"kavlan-16": "10.27.216.33",
"kavlan-17": "10.31.216.33",
"kavlan-18": "10.35.216.33",
"kavlan-2": "192.168.211.33",
"kavlan-20": "10.43.216.33",
"kavlan-21": "10.47.216.33",
"kavlan-3": "192.168.227.33",
"kavlan-4": "10.16.3.33",
"kavlan-5": "10.16.67.33",
"kavlan-6": "10.16.131.33",
"kavlan-7": "10.16.195.33",
"kavlan-8": "10.17.3.33",
"kavlan-9": "10.17.67.33"
"kavlan6": {
"eth0": {
"kavlan-1": "2001:660:4406:580:d::21",
"kavlan-11": "2001:660:4406:1a0:50d::21",
"kavlan-12": "2001:660:4406:2a0:50d::21",
"kavlan-13": "2001:660:4406:4a0:50d::21",
"kavlan-14": "2001:660:4406:5a0:50d::21",
"kavlan-16": "2001:660:4406:7a0:50d::21",
"kavlan-17": "2001:660:4406:9a0:50d::21",
"kavlan-18": "2001:660:4406:8a0:50d::21",
"kavlan-2": "2001:660:4406:581:d::21",
"kavlan-20": "2001:660:4406:3a0:50d::21",
"kavlan-21": "2001:660:4406:6a0:50d::21",
"kavlan-3": "2001:660:4406:582:d::21",
"kavlan-4": "2001:660:4406:590:d::21",
"kavlan-5": "2001:660:4406:591:d::21",
"kavlan-6": "2001:660:4406:592:d::21",
"kavlan-7": "2001:660:4406:593:d::21",
"kavlan-8": "2001:660:4406:594:d::21",
"kavlan-9": "2001:660:4406:595:d::21"
"main_memory": {
"ram_size": 206158430208
"management_tools": {
"bmc_vendor_tool": "racadm",
"ipmitool": {
"retries": 5
"memory_devices": [
"device": "dimm_a1",
"size": 17179869184,
"technology": "dram"
"device": "dimm_a2",
"device": "dimm_a3",
"device": "dimm_a4",
"device": "dimm_a5",
"device": "dimm_a6",
"device": "dimm_b1",
"device": "dimm_b2",
"device": "dimm_b3",
"device": "dimm_b4",
"device": "dimm_b5",
"device": "dimm_b6",
"network_adapters": [
"device": "eth0",
"driver": "i40e",
"enabled": true,
"firmware_version": "9.20 0x8000d956 22.0.9",
"interface": "Ethernet",
"ip": "172.16.76.33",
"ip6": "2001:660:4406:500:d::21",
"kavlan": true,
"mac": "3c:fd:fe:59:19:90",
"management": false,
"model": "Ethernet Controller X710 for 10GbE SFP+",
"mountable": true,
"mounted": true,
"name": "enp24s0f0",
"network_address": "grvingt-33.nancy.grid5000.fr",
"rate": 10000000000,
"sriov": false,
"sriov_totalvfs": 0,
"switch": "sgrvingt",
"switch_port": "TenGigabitEthernet 1/23",
"vendor": "Intel"
"device": "eth1",
"driver": "i40e",
"enabled": false,
"kavlan": false,
"mac": "3c:fd:fe:59:19:92",
"mountable": false,
"mounted": false,
"name": "enp24s0f1",
"sriov": false,
"vendor": "Intel"
"device": "ib0",
"driver": "hfi1",
"enabled": true,
"firmware_version": "1.27.0",
"guid": "0x0011750101091ff0",
"interface": "Omni-Path",
"ip": "172.18.76.33",
"kavlan": false,
"mac": "00:11:75:01:01:09:1f:f0",
"model": "Omni-Path HFI Silicon 100 Series [discrete]",
"mountable": true,
"mounted": true,
"name": "ib0",
"netmask": "255.255.255.0",
"network_address": "grvingt-33-ib0.nancy.grid5000.fr",
"rate": 100000000000,
"vendor": "Intel"
"device": "bmc",
"enabled": true,
"ip": "172.17.76.33",
"kavlan": false,
"mac": "50:9a:4c:85:cc:2c",
"management": true,
"mountable": false,
"mounted": false,
"network_address": "grvingt-33-bmc.nancy.grid5000.fr"
"nodeset": "grvingt",
"operating_system": {
"cstate_driver": "intel_idle",
"cstate_governor": "menu",
"ht_enabled": true,
"pstate_driver": "intel_pstate",
"pstate_governor": "performance",
"turboboost_enabled": true
"performance": {
"core_flops": 67200000000,
"node_flops": 2150400000000
"processor": {
"cache_l1": null,
"cache_l1d": 32768,
"cache_l1i": 32768,
"cache_l2": 1048576,
"cache_l3": 23068672,
"clock_speed": 2100000000,
"ht_capable": true,
"instruction_set": "x86-64",
"microarchitecture": "Skylake-SP",
"microcode": "0x2007006",
"model": "Intel Xeon",
"other_description": "Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz",
"vendor": "Intel",
"version": "Gold 6130"
"redfish": true,
"software": {
"forced-deployment-timestamp": 202007300948,
"postinstall-version": "1.2024112508",
"standard-environment": "debian11-x64-std"
"storage_devices": [
"by_id": "/dev/disk/by-id/wwn-0x5000c500b9158fb9",
"by_path": "/dev/disk/by-path/pci-0000:00:11.5-ata-3",
"firmware_version": "NB33",
"id": "disk0",
"interface": "SATA",
"model": "ST1000NX0443",
"size": 1000204886016,
"storage": "HDD",
"vendor": "Seagate"
"supported_job_types": {
"besteffort": true,
"deploy": true,
"max_walltime": 604800,
"queues": [
"admin",
"production"
"virtual": "ivt"
"type": "node",
"uid": "grvingt-33"
\ No newline at end of file
...@@ -144,10 +144,6 @@ ...@@ -144,10 +144,6 @@
"uid": "grvingt-37" "uid": "grvingt-37"
"kind": "node",
"port": "eth0",
"snmp_name": "TenGigabitEthernet 1/23",
"uid": "grvingt-33"
"kind": "node", "kind": "node",
...@@ -9,6 +9,8 @@ queues: ...@@ -9,6 +9,8 @@ queues:
- production - production
nodes: nodes:
grvingt-33:
status: retired
grvingt-[1-64]: grvingt-[1-64]:
processor: processor:
microarchitecture: Skylake-SP microarchitecture: Skylake-SP
# Generated by g5k-checks (g5k-checks -m api)
grvingt-33:
architecture:
cpu_core_numbering: round-robin
nb_cores: 32
nb_procs: 2
nb_threads: 64
platform_type: x86_64
bios:
release_date: 06/12/2023
vendor: Dell Inc.
version: 2.19.1
bmc_version: 6.10.80.00
chassis:
manufacturer: Dell Inc.
serial: CP48DP2
main_memory:
ram_size: 206158430208
memory_devices:
dimm_a1:
technology: dram
dimm_a2:
technology: dram
dimm_a3:
technology: dram
dimm_a4:
technology: dram
dimm_a5:
technology: dram
dimm_a6:
technology: dram
dimm_b1:
technology: dram
dimm_b2:
technology: dram
dimm_b3:
technology: dram
dimm_b4:
technology: dram
dimm_b5:
technology: dram
dimm_b6:
technology: dram
network_adapters:
bmc:
ip: 172.17.76.33
mac: 50:9a:4c:85:cc:2c
management: true
eth0:
driver: i40e
firmware_version: 9.20 0x8000d956 22.0.9
interface: Ethernet
ip: 172.16.76.33
mac: 3c:fd:fe:59:19:90
management: false
model: Ethernet Controller X710 for 10GbE SFP+
rate: 10000000000
sriov: false
sriov_totalvfs: 0
vendor: Intel
eth1:
driver: i40e
interface: Ethernet
mac: 3c:fd:fe:59:19:92
management: false
sriov: false
sriov_totalvfs: 0
vendor: Intel
ib0:
driver: hfi1
firmware_version: 1.27.0
guid: '0x0011750101091ff0'
interface: Omni-Path
ip: 172.18.76.33
mac: 00:11:75:01:01:09:1f:f0
management: false
model: Omni-Path HFI Silicon 100 Series [discrete]
rate: 100000000000
vendor: Intel
operating_system:
cstate_driver: intel_idle
cstate_governor: menu
ht_enabled: true
pstate_driver: intel_pstate
pstate_governor: performance
turboboost_enabled: true
processor:
cache_l1d: 32768
cache_l1i: 32768
cache_l2: 1048576
cache_l3: 23068672
ht_capable: true
instruction_set: x86-64
microcode: '0x2007006'
model: Intel Xeon
other_description: Intel(R) Xeon(R) Gold 6130 CPU @ 2.10GHz
vendor: Intel
version: Gold 6130
storage_devices:
pci-0000:00:11.5-ata-3:
by_id: "/dev/disk/by-id/wwn-0x5000c500b9158fb9"
by_path: "/dev/disk/by-path/pci-0000:00:11.5-ata-3"
firmware_version: NB33
model: ST1000NX0443
storage: HDD
supported_job_types:
virtual: ivt
...@@ -87,7 +87,6 @@ sgrvingt: ...@@ -87,7 +87,6 @@ sgrvingt:
20: grvingt-44 20: grvingt-44
21: grvingt-38 21: grvingt-38
22: grvingt-37 22: grvingt-37
23: grvingt-33
24: grvingt-34 24: grvingt-34
25: grvingt-29 25: grvingt-29
26: grvingt-30 26: grvingt-30
