Commit 01861b85 authored by Simon Delamare's avatar Simon Delamare
[lyon] remove all BMC metrics from hercule, too unreliable
parent 43b03fcb
Pipeline #794153 passed
......@@ -4,236 +4,6 @@
"exotic": false,
"kavlan": true,
"metrics": [
"description": "Front node ambient temperature reported by BMC, in celsius",
"name": "bmc_ambient_temp_celsius",
"period": 5000,
"source": {
"id": 49,
"protocol": "ipmisensor"
"description": "Voltage of 12V Standby reported by BMC, in volt",
"labels": {
"id": "12v_standby"
"name": "bmc_other_voltage_volt",
"optional_period": 5000,
"period": 0,
"source": {
"id": 5,
"description": "Voltage of 5V Standby reported by BMC, in volt",
"labels": {
"id": "5v_standby"
"period": 0,
"source": {
"id": 6,
"description": "Voltage of 5V reported by BMC, in volt",
"labels": {
"id": "5v"
"period": 0,
"source": {
"id": 7,
"description": "Voltage of 3.3V Standby reported by BMC, in volt",
"labels": {
"id": "3.3v_standby"
"period": 0,
"source": {
"id": 8,
"description": "Voltage of 3.3V reported by BMC, in volt",
"labels": {
"id": "3.3v"
"period": 0,
"source": {
"id": 9,
"description": "Temperature of MEZZ1 reported by BMC, in celsius",
"labels": {
"id": "mezz1"
"name": "bmc_other_temp_celsius",
"period": 0,
"source": {
"id": 11,
"description": "Temperature of CPU1 reported by BMC, in celsius",
"labels": {
"cpu": "1"
"name": "bmc_cpu_temp_celsius",
"period": 0,
"source": {
"id": 12,
"description": "Temperature of CPU2 reported by BMC, in celsius",
"labels": {
"cpu": "2"
"period": 0,
"source": {
"id": 13,
"description": "Temperature of DIMM ZONE 1 reported by BMC, in celsius",
"labels": {
"id": "dimm_zone_1"
"period": 0,
"source": {
"id": 14,
"description": "Temperature of DIMM ZONE 2 reported by BMC, in celsius",
"labels": {
"id": "dimm_zone_2"
"period": 0,
"source": {
"id": 15,
"description": "Temperature of PCH reported by BMC, in celsius",
"labels": {
"id": "pch"
"period": 0,
"source": {
"id": 18,
"description": "Voltage of input reported by BMC, in volt",
"labels": {
"id": "input"
"period": 0,
"source": {
"id": 51,
"description": "Current of input reported by BMC, in amp",
"labels": {
"id": "input"
"name": "bmc_other_current_amp",
"period": 0,
"source": {
"id": 52,
"description": "Speed of fan 1 reported by BMC, in rpm",
"labels": {
"fan": "_1"
"name": "bmc_fan_speed_rpm",
"period": 0,
"source": {
"id": 96,
"description": "Speed of fan 2 reported by BMC, in rpm",
"labels": {
"fan": "_2"
"period": 0,
"source": {
"id": 97,
"description": "Speed of fan 3 reported by BMC, in rpm",
"labels": {
"fan": "_3"
"period": 0,
"source": {
"id": 98,
"description": "Speed of fan 4 reported by BMC, in rpm",
"labels": {
"fan": "_4"
"period": 0,
"source": {
"id": 99,
"description": "Default subset of metrics from Prometheus Node Exporter",
"name": "prom_default_metrics",
......@@ -8,166 +8,6 @@ metrics:
# source:
# protocol: wattmetre
- name: bmc_ambient_temp_celsius
description: Front node ambient temperature reported by BMC, in celsius
period: 5000
source:
protocol: ipmisensor
id: 49 # Inlet Temp
- name: bmc_other_voltage_volt
labels: {"id": "12v_standby"}
description: Voltage of 12V Standby reported by BMC, in volt
period: 0
optional_period: 5000
source:
id: 5 # 12V Standby
labels: {"id": "5v_standby"}
description: Voltage of 5V Standby reported by BMC, in volt
period: 0
source:
id: 6 # 5V Standby
labels: {"id": "5v"}
description: Voltage of 5V reported by BMC, in volt
period: 0
source:
id: 7 # 5V
labels: {"id": "3.3v_standby"}
description: Voltage of 3.3V Standby reported by BMC, in volt
period: 0
source:
id: 8 # 3.3V Standby
labels: {"id": "3.3v"}
description: Voltage of 3.3V reported by BMC, in volt
period: 0
source:
id: 9 # 3.3V
- name: bmc_other_temp_celsius
labels: {"id": "mezz1"}
description: Temperature of MEZZ1 reported by BMC, in celsius
period: 0
source:
id: 11 # MEZZ1 TEMP
- name: bmc_cpu_temp_celsius
labels: {"cpu": "1"}
description: Temperature of CPU1 reported by BMC, in celsius
period: 0
source:
id: 12 # CPU1 Temp
labels: {"cpu": "2"}
description: Temperature of CPU2 reported by BMC, in celsius
period: 0
source:
id: 13 # CPU2 Temp
labels: {"id": "dimm_zone_1"}
description: Temperature of DIMM ZONE 1 reported by BMC, in celsius
period: 0
source:
id: 14 # DIMM ZONE 1 Temp
labels: {"id": "dimm_zone_2"}
description: Temperature of DIMM ZONE 2 reported by BMC, in celsius
period: 0
source:
id: 15 # DIMM ZONE 2 Temp
labels: {"id": "pch"}
description: Temperature of PCH reported by BMC, in celsius
period: 0
source:
id: 18 # PCH Temp
labels: {"id": "input"}
description: Voltage of input reported by BMC, in volt
period: 0
source:
id: 51 # Input Voltage
- name: bmc_other_current_amp
description: Current of input reported by BMC, in amp
period: 0
source:
id: 52 # Input Current
- name: bmc_fan_speed_rpm
labels: {"fan": "_1"}
description: Speed of fan 1 reported by BMC, in rpm
period: 0
source:
id: 96 # FAN_1
labels: {"fan": "_2"}
description: Speed of fan 2 reported by BMC, in rpm
period: 0
source:
id: 97 # FAN_2
labels: {"fan": "_3"}
description: Speed of fan 3 reported by BMC, in rpm
period: 0
source:
id: 98 # FAN_3
labels: {"fan": "_4"}
description: Speed of fan 4 reported by BMC, in rpm
period: 0
source:
id: 99 # FAN_4
- name: prom_default_metrics
description: Default subset of metrics from Prometheus Node Exporter
period: 0
