Commit 00666917 authored by Lucas Nussbaum's avatar Lucas Nussbaum
[input_loader & gens] allow sites without kavlan
parent ec5daf16
1 merge request!717Draft: Allow sites without kavlan ; make strasbourg such a site
...@@ -42,6 +42,7 @@ def generate_puppet_kavlang5k(options) ...@@ -42,6 +42,7 @@ def generate_puppet_kavlang5k(options)
refapi['sites'].each { |site_uid, site_refapi| refapi['sites'].each { |site_uid, site_refapi|
next if not site_refapi['kavlans'] # skip sites without kavlan
next unless options[:sites].include?(site_uid) next unless options[:sites].include?(site_uid)
conf = YAML::load(ERB.new(File.read("#{options[:conf_dir]}/kavlang5k.yaml"), trim_mode: '-').result(binding))[site_uid] conf = YAML::load(ERB.new(File.read("#{options[:conf_dir]}/kavlang5k.yaml"), trim_mode: '-').result(binding))[site_uid]
...@@ -36,6 +36,7 @@ end ...@@ -36,6 +36,7 @@ end
def build_stitcher_kavlans_hash(refapi) def build_stitcher_kavlans_hash(refapi)
stitcher_kavlans_hash = {} stitcher_kavlans_hash = {}
refapi['sites'].each do |name, site_hash| refapi['sites'].each do |name, site_hash|
next if not site_hash['kavlans'] # skip sites without kavlan
global_kavlan = site_hash['kavlans'].select { | id, _hash | id =~ /\d\d/ }.first global_kavlan = site_hash['kavlans'].select { | id, _hash | id =~ /\d\d/ }.first
global_kavlan_id = global_kavlan.first.to_i global_kavlan_id = global_kavlan.first.to_i
stitcher_kavlans_hash[global_kavlan_id] = {"vlan" => 700 + global_kavlan_id, "site" => name} stitcher_kavlans_hash[global_kavlan_id] = {"vlan" => 700 + global_kavlan_id, "site" => name}
...@@ -507,6 +507,7 @@ def add_kavlan_ipv6s(h) ...@@ -507,6 +507,7 @@ def add_kavlan_ipv6s(h)
h['ipv6']['site_global_kavlans'].each { |key, value| global_vlan_site[value] = key } h['ipv6']['site_global_kavlans'].each { |key, value| global_vlan_site[value] = key }
# Set kavlan ipv6 informations at site level # Set kavlan ipv6 informations at site level
h['sites'].each_pair do |site_uid, hs| h['sites'].each_pair do |site_uid, hs|
next if not hs['kavlans'] # skip sites without kavlan
site_prefix = IPAddress hs['ipv6']['prefix'] site_prefix = IPAddress hs['ipv6']['prefix']
kavlan_ids = h['vlans']['base'].map{ |k,v| k if v["type"] =~ /local|routed/ }.compact + [h['ipv6']['site_global_kavlans'][site_uid]] kavlan_ids = h['vlans']['base'].map{ |k,v| k if v["type"] =~ /local|routed/ }.compact + [h['ipv6']['site_global_kavlans'][site_uid]]
kavlan_ids.each do |kvl_id| kavlan_ids.each do |kvl_id|
