Commit 83efd9fe authored by Alexandre MERLIN's avatar Alexandre MERLIN
release 3.8.0
parent 2627cf38
Pipeline #454662 passed
3.7.7.stable 3.8.0.stable
kadeploy (3.8.0.stable) unstable; urgency=low
* 080c249 [kaworkflow] fallback to default arch of the first node when using api and no arch specified
* e783f40 rename deploymentEnv in deploymentMiniOS
-- Alexandre MERLIN <alexandre.merlin@inria.fr> Wed, 16 Mar 2022 11:07:18 +0100
kadeploy (3.7.7.stable) unstable; urgency=low kadeploy (3.7.7.stable) unstable; urgency=low
* f2797ac add startup script step * f2797ac add startup script step
* 065b641 [karight] allow karight to be used in nodes with different archs * 065b641 [karight] allow karight to be used in nodes with different archs
* 96b5b76 [kaenv] correctly process --env_version in kaenv * 96b5b76 [kaenv] correctly process --env_version in kaenv
-- Alexandre MERLIN <alexandre.merlin@inria.fr> Mon, 24 Jan 2022 13:44:33 +0100 -- Alexandre MERLIN <alexandre.merlin@inria.fr> Mon, 24 Jan 2022 13:44:33 +0100
