GitLab
Explore
Primary navigation
Search or go to…
P
python
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Model registry
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Admin message
GitLab upgrade completed. Current version is 17.11.4.
This is an archived project. Repository and other project resources are read-only.
Show more breadcrumbs
grew
python
33fe2e6b
33fe2e6b
4 years ago
Bruno Guillaume
Downloads
Patches
separated install_dev
ff7d8676
3
3 changed files
Makefile
+1
-4
1 addition, 4 deletions
Makefile
_tags
+1
-1
1 addition, 1 deletion
_tags
install_dev
+2
2 additions, 0 deletions
install_dev
4 additions
5 deletions
Makefile
4
33fe2e6b
@@ -9,10 +9,7 @@ VERSION = `cat VERSION`
default
native
default
native
native
native
OCB
grewpy.native
OCB
-tag-line
"true: package(libgrew)"
grewpy.native
byte
OCB
grewpy.byte
install
native
install
native
mkdir
-p
BINDIR
mkdir
-p
BINDIR
This diff is collapsed.
_tags
33fe2e6b
true: package(yojson, threads, unix, str, containers, ANSITerminal, log, conll, amr
, libgrew
true: package(yojson, threads, unix, str, containers, ANSITerminal, log, conll, amr)
true: thread
true: thread
true: bin_annot
true: bin_annot
\ No newline at end of file
install_dev
0 → 100755
2
33fe2e6b
ocamlbuild -use-ocamlfind -I src_ocaml -tag-line "true: package(libgrew_dev)" grewpy.native
cp grewpy.native ~/.local/bin/grewpy_dev
Loading
Save comment
