Commit 01dc1834 authored by Bruno Guillaume's avatar Bruno Guillaume
more test
parent 1d44af41
import sys
import grew
grew.init(True) # local usage --> run grewpy_dev
gsd = grew.corpus (["UD_French-GSD/fr_gsd-ud-dev.conllu", "UD_French-GSD/fr_gsd-ud-test.conllu", ])
# graph = grew.corpus_get (gsd, "fr-ud-dev_00002")
# print(graph)
print (grew.corpus_size (gsd))
ids = grew.corpus_sent_ids(gsd)
print (ids[10:20])
try:
graph = grew.corpus_get ("fr-ud-dev_00002", gsd)
svg = grew.graph_svg(graph)
print(svg)
except grew.utils.GrewError as err:
print ("ERROR: %s" % err)
# Import the library
import grew
# Run the grew tool in background
grew.init()
# Load the corpus file (of course, you will have to update the filename to your system)
c = grew.corpus ("/users/guillaum/gitlab/deep-sequoia/trunk/sequoia.deep_and_surf.conll")
# Search for an empty pattern and print the number of occurences
r = grew.corpus_search ("pattern {}", c)
print (len (r))
\ No newline at end of file
import grew
grew.init(True)
g = grew.graph('''graph {
W1 [form="le", lemma="le", cat=DET];
W2 [form="garçon", lemma="garçon", cat=NOUN];
W3 [form="voit", lemma="voir", cat=VERB];
W4 [form="la", lemma="le", cat=DET];
W5 [form="maison", lemma="maison", cat=NOUN];
r = grew.grs('''
rule set_gender {
pattern { N [upos=NOUN, !Gender, lemma=lex.noun] }
commands { N.Gender = lex.Gender }
#BEGIN lex
noun Gender
garçon Masc
maison Fem
#END
out = grew.run(r, g, 'Iter(set_gender)')
print (out)
import grew
import sys
import json
seq = grew.corpus(["UD_French-GSD/fr_gsd-ud-test.conllu", "UD_French-GSD/fr_gsd-ud-dev.conllu", "UD_French-GSD/fr_gsd-ud-train.conllu"])
print ("|NOUN| = " + json.dumps (grew.corpus_count("pattern { N[upos=NOUN] }", seq)))
print ("|NOUN| -[cop]-> = " + json.dumps (grew.corpus_count("pattern { N[upos=NOUN]; N -[cop]-> * }", seq)))
print (" -[nsubj]-> |NOUN| = " + json.dumps (grew.corpus_count("pattern { * -[nsubj]-> N; N[upos=NOUN]; }", seq)))
