GitLab
Explore
Primary navigation
Search or go to…
G
gnomon-package-tissueimagemesh
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Model registry
Operate
Environments
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
gnomon
gnomon-packages
86a86061
86a86061
8 months ago
CERUTTI Guillaume
Downloads
Patches
remove deprecated draco plugin + fix curvature test
7db7b646
Pipeline
#1014522
failed
7 months ago
Stage: test
Stage: build
Stage: deploy
3
3 changed files
setup.py
+1
-1
1 addition, 1 deletion
setup.py
test/test_gnomonCellComplexFromCellImage.py
+9
-9
9 additions, 9 deletions
test/test_surfaceMeshCurvature.py
+2
-2
2 additions, 2 deletions
12 additions
12 deletions
setup.py
86a86061
@@ -38,7 +38,7 @@ setup_kwds = dict(
entry_points
entry_points
cellComplexFromCellImage
cellReconstructionGrifone = gnomon_package_tissueimagemesh.algorithm.cellComplexFromCellImage.cellReconstructionGrifone
cellReconstructionDracoStem = gnomon_package_tissueimagemesh.algorithm.cellComplexFromCellImage.cellReconstructionDracoStem
'cellReconstructionDracoStem = gnomon_package_tissueimagemesh.algorithm.cellComplexFromCellImage.cellReconstructionDracoStem'
cellImageQuantification
surfaceMeshCellCurvature = gnomon_package_tissueimagemesh.algorithm.cellImageQuantification.surfaceMeshCellCurvature
This diff is collapsed.
9
9
86a86061
@@ -23,19 +23,19 @@ class TestGnomonCellComplexFromCellImage(unittest.TestCase):
self
cellImage
self
reader
cellImage
self
cellImage
self
reader
cellImage
self
draco_stem
gnomon
core
cellComplexFromCellImage_pluginFactory
create
cellReconstruction
DracoStem
self
grifone
gnomon
core
create
cellReconstruction
Grifone
def
tearDown
self
def
tearDown
self
self
reader
this
disown
self
reader
this
disown
self
draco_stem
this
disown
self
grifone
this
disown
def
test_gnomonCellComplexFromCellImage_2d
self
def
self
self
draco_stem
setInput
self
cellImage
self
grifone
setInput
self
cellImage
self
draco_stem
refreshParameters
self
grifone
refreshParameters
self
draco_stem
setParameter
dimension
3
self
grifone
setParameter
dimension
2
self
draco_stem
run
self
grifone
run
assert
self
draco_stem
output
is
not
None
assert
self
grifone
output
is
not
None
cellcomplex
self
draco_stem
output
cellcomplex
self
grifone
output
assert
cellcomplex
elementCount
3
assert
cellcomplex
elementCount
2
# test_gnomonCellComplexFromCellImage.py ends here.
2
2
86a86061
@@ -34,8 +34,8 @@ class TestSurfaceMeshCurvature(unittest.TestCase):
self
curvature
refreshParameters
self
curvature
refreshParameters
self
curvature
run
self
curvature
run
assert
self
curvature
c
ellImage
is
not
None
assert
self
curvature
outputC
ellImage
is
not
None
cellImage
self
curvature
c
ellImage
cellImage
self
curvature
outputC
ellImage
assert
mean_curvature
in
cellImage
cellPropertyNames
assert
mean_curvature
in
cellImage
cellPropertyNames
Loading
Save comment
