Commit 670bfb37 authored by Tomofumi Yuki's avatar Tomofumi Yuki
moved naming of types for exploration to SolutionSpace instead of
internally in profiler
parent 712ee4a0
1 merge request!4Develop
......@@ -284,6 +284,10 @@ class SolutionSpace {
EcoreUtil.copy(this)
op String getUniqueTypeName(Symbol s) {
return "TYPE_" + s.getName() + "_" + exploredSymbols.indexOfKey(s)
op String toString() {
"Solution Space (" + exploredSymbols.size + "):\n"
+ getSymbols.join("\n", ["\tSymbol '" + SolutionSpaceUtils.printSymbol(it) + "' (" + it.class.simpleName + "):\n" + getTypeSpace(it)])
......@@ -262,6 +262,15 @@ public interface SolutionSpace extends EObject {
SolutionSpace copy();
* <!-- begin-user-doc -->
* <!-- end-user-doc -->
* @model unique="false" sUnique="false"
* annotation="http://www.eclipse.org/emf/2002/GenModel body='&lt;%java.lang.String%&gt; _name = s.getName();\n&lt;%java.lang.String%&gt; _plus = (\"TYPE_\" + _name);\n&lt;%java.lang.String%&gt; _plus_1 = (_plus + \"_\");\nint _indexOfKey = this.getExploredSymbols().indexOfKey(s);\nreturn (_plus_1 + &lt;%java.lang.Integer%&gt;.valueOf(_indexOfKey));'"
* @generated
String getUniqueTypeName(Symbol s);
......@@ -410,6 +410,19 @@ public class SolutionSpaceImpl extends MinimalEObjectImpl.Container implements S
return EcoreUtil.<SolutionSpace>copy(this);
* @generated
public String getUniqueTypeName(final Symbol s) {
String _name = s.getName();
String _plus = ("TYPE_" + _name);
String _plus_1 = (_plus + "_");
return (_plus_1 + Integer.valueOf(_indexOfKey));
......@@ -841,6 +841,9 @@ public class TypeexplorationPackageImpl extends EPackageImpl implements Typeexpl
addEOperation(solutionSpaceEClass, this.getSolutionSpace(), "copy", 0, 1, !IS_UNIQUE, IS_ORDERED);
op = addEOperation(solutionSpaceEClass, theEcorePackage.getEString(), "getUniqueTypeName", 0, 1, !IS_UNIQUE, IS_ORDERED);
addEParameter(op, theCorePackage.getSymbol(), "s", 0, 1, !IS_UNIQUE, IS_ORDERED);
addEOperation(solutionSpaceEClass, theEcorePackage.getEString(), "toString", 0, 1, !IS_UNIQUE, IS_ORDERED);
// Initialize data types
......@@ -71,7 +71,7 @@ class InternalProfiler {
this.referenceSolution = UserFactory.solution(solutionSpace);
/** replace type of s by a alias */
solutionSpace.getSymbols().forEach(this::generalizeType);
solutionSpace.getSymbols().forEach(s->generalizeType(solutionSpace, s));
* if multiple symbol have same generic type name, this mean that multiple symbols
......@@ -91,7 +91,7 @@ class InternalProfiler {
private void generalizeType(Symbol s) {
private void generalizeType(SolutionSpace sol, Symbol s) {
GecosUserTypeFactory.setScope(s.getContainingScope().getRoot());
TypeAnalyzer ta = new TypeAnalyzer(s.getType());
......@@ -114,7 +114,7 @@ class InternalProfiler {
pragma(lookupAliasType, CODEGEN_IGNORE_ANNOTATION);
} else {
/* create a macro generic Type */
genericTypeName = getGenericTypeName(s);
genericTypeName = getGenericTypeName(sol, s);
Type generic = ALIAS(VOID(), genericTypeName);
......@@ -135,10 +135,10 @@ class InternalProfiler {
int uid = 0;
private String getGenericTypeName(Symbol s) {
private String getGenericTypeName(SolutionSpace sol, Symbol s) {
String name = symbolGenericTypeNameMap.get(s);
if(name == null) {
name = "TYPE_" + s.getName() + "_" + (uid++);
name = sol.getUniqueTypeName(s);
setGenericTypeName(s, name);
return name;
......@@ -156,7 +156,7 @@ class InternalProfiler {
Map<String, String> typeDefMacros = solution.getSymbols().stream()
.collect(toMap( s -> getGenericTypeName(s),
.collect(toMap( s -> getGenericTypeName(solution.getSolutionSpace(), s),
s -> generator.generate(solution.getType(s))));
if(solIDName.equals(SimulationAccuracyEvaluator.REF_IMPLEM_NAME))
