Migration to git
:gecos: GeCoS
:toc:
Introduction
{gecos} is a large project with a bit less that a thousand eclipse plugins.
So far, it has been handled as one big piece of software:
* One SVN repository used for source code management.
* The whole project is build/deployed at once from sources i.e.
internal dependencies (between {gecos} plugins) are satisfied from sources directly.
Few of the main problems with this approach are:
* Many unused plugins becomes obsolete and pollute the SVN repository. +
When compatibility-breaking modfifications
are performed on other used plugins, we either need to update such plugins
(tedious, time consuming) to be able to build the project or exclude
them from the build, which essentially turns them into zombies.
* The build/test process is long and tedious.
* Plugins Versionning is virtually impossible.
* Branch/Merge operations are very tedious which
To help solving these problems, most active {gecos} plugins from the SVN repository
are being orginized into small groups (per functionality) and moved to independent git
repositories at https://gitlab.inria.fr/gecos[inria Gitlab].
Each group of {gecos} plugins centered arround one (or more) functionality are
bundled into a higher level entity, reffered to as *{gecos} project*.
A {gecos} project is treated as an independent peace of software with:
* proper versioning and dependencies management
* an associated git repository
* a (versioned) _release_ p2 repositoy (eclipse update site) maintained indefinetly
* other short-lived p2 repositories (_snapshot_ and _testing_)
* a build/test/deploy/ Continuous Integration system.
The aim is to ultimately make every {gecos} project
https://en.wikipedia.org/wiki/Continuous_delivery[Continuously deliverable].
Projects decomposition
The so far available {gecos} projects are:
gecos-framework
This project contains the {gecos} Framework including, the compiler eclipse application,
eclipse run/debug configuration, compiler script (.cs) editor, script module/primitive
extension mechanism and other UI functionalities.
Dependencies: []
gecos-testframework
This project contains the integration testing framework along with some test resources
(C code applications ...).
Dependencies: [gecos-framework]
gecos-tools
This is a sub-group with 4 projects providing various external and internal tools:
* *gecos-tools-tomsdk*: wrap external http://tom.loria.fr[TOM] language SDK.
* *gecos-tools-tommapping*: Define an Xtext-based DSL for easily generating
TOM mappings for Ecore/Xcore models.
* *gecos-tools-graph*: wrap external http://jgrapht.org/[JGraphT] library
and provide a generic graph model (IGraph).
* *gecos-tools-emf*: provides various tools related but not restricted to
http://www.eclipse.org/modeling/emf/[Eclipse Modeling Framework (EMF)].
gecos-core
This project contains the CDFG model, the CDT front-end and C code generator.
It is meant to be the minimal set of plugins needed to get a working C-to-C compilation flow.
[WARNING]
Currently other plugins such as transforms, analysis, utils, dag-adapter...
are included in this project, but these might be separated in the future.
Dependencies: [gecos-framework, gecos-testframework and gecos-tools.]
Project Structure
At the root directory of a {gecos} project you find the following:
* *bundles/*: contains all the eclipse plugins that constitute the main sources of the project.
* *tests/*: contains one or more eclipse feature project (define groups of eclipse plugins)
* *features/*: contains all the eclipse features (*.feature)
* *releng/*: contains all release related sources, mainly:
** ***.update/**: eclipse update site; defines the set of features/plugins to be included in
the p2 update site, and organize them into categories
** ***.target/**: eclipse http://www.vogella.com/tutorials/EclipseTargetPlatform/article.html[target plateform definition]; defines the dependencies of the project.
[IMPORTANT]
A target definition project named <__name__> must contain a target definition file named <__name__>__.target__. +
e.g.: gecos.target__.target __ if the project name is gecos.target
* *.mvn/*: contains the https://maven.apache.org/what-is-maven.html[Maven] related settings
such as https://maven.apache.org/settings.html[extensions.xml] file.
* *.gitignore*: contains path patterns that should be ignored by git
* *README.md*: contains various information about the project, its documentation site,
update site, installation procedure ...
* *CHANGELOG.md*: contains release change logs.
It MUST be maintained with each new version release !
* https://maven.apache.org/pom.html[*pom.xml*]: Maven configuration file.
* https://docs.gitlab.com/ee/ci/yaml/[*.gitlab-ci.yml*]: Gitlab CI configuration file.
Naming Convention
The name of a {gecos} project should follow the template: *gecos-<__pname__>* +
where <__pname__> should be:
* very concise description of the main functionality of the project, preferably one word
* should not use uppercase
All sources (bundles, features, tests, releng) in a project shoule be named:
*fr.irisa.cairn.gecos.<__pname*__>.<__suffix__>* +
where:
* <__pname*__> is <__pname__> without any \'-'.
e.g.: <__pname__>= "test-framework" then <__pname*__> = "testframework"
* <__suffix__> must end with ".feature", ".update" and ".target" for feature, update site
and target definition eclipse projects, respectively.
Versioning/Dependencies management
[[section-versioning, Versioning]]
Versioning
Each {gecos} project is considered as an independent, atomic, piece of software.
It can thus evolve independently from other projects.
The version management is performed at the project level. That is,
all bundles/features in a project are considered to have the **SAME** version
even if some remains unchanged between versions.
This is in order to simplify the versioning procedure and avoid the hassle of properly
versioning every eclipse project independently.
The versioning follows the http://semver.org[Semantic Versioning Specification].
In short, a version number is composed of *MAJOR.MINOR.PATCH*, where:
* *MAJOR* is incremented when making incompatible API changes
* *MINOR* is incremented when adding functionality in a backwards-compatible manner
* *PATCH* is incremented when making backwards-compatible bug fixes.
Dependencies
The set of all dependencies (including to other {gecos} projects) needed to
build a {gecos} project are specified using an
https://wiki.eclipse.org/PDE/Target_Definitions[eclipse target definition file]
named "<__prefix__>.target.target" located at "/releng/<__prefix__>.target"
in the project's sources repository.
WARNING: Only p2 repositories must be used in the target definition file to specify dependencies.
Internal dependencies (i.e. between {gecos} projects) are resolved through
artifacts distributed on their associated update sites (p2 reposiories).
This enforces the boundaries between {gecos} projects and allow each project
to evolve independently without breaking other projects.
For instance, a dependency to another {gecos} project <__pname2__> at version <__X.Y.Z__>
MUST be specified in the target definition file from its update site with the proper version number: +
<__siteURL__>/gecos/<__pname2__>/release/<__X.Y.Z__>/
WARNING: DO NOT use the latest version link !
This ensures that each project can safely evolve independently from other {gecos} projects without breaking other dependent projects.
To ensure to correct functionning, the new {gecos} update site structure must be handles with extreme cautiousness.
Always back it up before doing any manipulation.
Be careful in case you want to perform a restructuring of the update site, In this case you need to keep in mind and properly modify the target definition files of all projects.
<<section-update-site, Update site section>>
[[section-update-site, Update site]]
{gecos} Update Site (p2 repository)
The gecos update site is currently hosted at (`<siteURL>`):
http://gecos.gforge.inria.fr/updatesite/ .
It contains an entry per {gecos} project.
The one associated with the project "gecos-<__name__>" is located at: `<siteURL>/gecos/<name>/`
and is structured as follows:
* *release/*: contains all released versions (kept for a very long time)
** *<__version__>/*: one release version (see <<section-versioning, Versioning>>)
** *latest/*: link to the latest release version
* *snapshot/*: contains in-between releases develop snapshots (kept at least til the second next release)
** *<__timestamp__>/*: Europe/Paris UTC snapshot build date in `YYYYMMDDhhmmss` format
** *latest/*: link to the latest snapshot version
* *testing/*: contains temporary snapshots (can be removed at anytime!)
** *latest/*: link to the latest testing version
