GitLab
Explore
Primary navigation
Search or go to…
U
uml-models
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Gazelle
Library
uml-models
2e0fcfb3
2e0fcfb3
2 years ago
Achraf Achkari
Downloads
Patches
update gitlab-ci
634d0481
Branches containing commit
Tags containing commit
2 merge requests
!14
Develop
!13
Feature/cdaepsos4 update
.gitlab-ci.yml
+36
-16
36 additions, 16 deletions
.gitlab-ci.yml
36 additions
16 deletions
.gitlab-ci.yml
36
16
2e0fcfb3
# Define templates
include
project
gazelle/private/gitlab-ci-templates'
file
extends.yaml'
ref
master
file
extends
-v2
.yaml'
ref
1.0.0
# Define stages
stages
build
p
ostbuild
p
redeploy
deploy
tests
test
publish
release
upgrade
cleanup
# Define global variables
variables
P_NAME
uml-models"
P_APP_TYPE
java"
P_CODE_SRC_PATH
P_MAVEN_IMAGE_TAG
3.6.3-jdk-11-slim"
# Define jobs
code
compile/unit-test
stage
build
extends
.build
CodeForJavaWithPostgresql
.build
JavaMavenTest
variables
P_MAVEN_EXTRA_ARGS
-DskipIT
=true
P_MAVEN_EXTRA_ARGS
-DskipIT
s
quality
stage
tests
package
stage
build
extends
testQualityForJavaWithSonarqub
e
buildJavaMavenPackag
e
variables
P_MAVEN_IMAGE_TAG
3.6.3-jdk-11"
P_MAVEN_EXTRA_ARGS
-DskipTests"
needs
job
compile/unit-test
artifacts
true
install-cache-repo
stage
publish
extends
.publishJavaMavenInstall
variables
P_MAVEN_EXTRA_ARGS
-DskipTests
needs
job
package
artifacts
true
publish-code
stage
publish
extends
.publishJavaMavenDeploy
needs
job
package
artifacts
true
release/code
stage
release
extends
.releaseCodeForJava
when
manual
variables
P_MAVEN_
EXTRA_ARGS
-DskipIT=
true"
P_MAVEN_
JAVADOC_SKIP
true"
This diff is collapsed.
Loading
Save comment
