Commit cc06e9e8 authored by Achraf Achkari's avatar Achraf Achkari
Fix follow redirect for distant decor retrieving
parent 32312d2f
2 merge requests!44Develop,!43Feature/cdapesos4 update
Pipeline #738420 failed
...@@ -232,7 +232,7 @@ public class AttributeAnalyzer extends AttributeProcessorImpl { ...@@ -232,7 +232,7 @@ public class AttributeAnalyzer extends AttributeProcessorImpl {
@Override @Override
public void processIsOptional(Boolean isOptional) { public void processIsOptional(Boolean isOptional) {
if ((isOptional == null || !isOptional.booleanValue()) && (selectedAttribute.isProhibited() != null && !selectedAttribute.isProhibited().booleanValue())){ if ((isOptional == null || !isOptional.booleanValue()) ){
List<String> listAttrNames = AttributeUtil.getListAttributesNames(selectedAttribute); List<String> listAttrNames = AttributeUtil.getListAttributesNames(selectedAttribute);
for (String attrName : listAttrNames) { for (String attrName : listAttrNames) {
if (AttributeUtil.assertAttributeIsNotRequiredByDefault(this.selectedAttribute, attrName)){ if (AttributeUtil.assertAttributeIsNotRequiredByDefault(this.selectedAttribute, attrName)){
...@@ -229,5 +229,6 @@ ...@@ -229,5 +229,6 @@
<version>1.4.1</version> <version>1.4.1</version>
</dependency> </dependency>
</dependencies> </dependencies>
</project> </project>
package net.ihe.gazelle.tempmodel.org.decor.art.utils; package net.ihe.gazelle.tempmodel.org.decor.art.utils;
import java.io.FileInputStream; import net.ihe.gazelle.tempmodel.org.decor.art.model.Decor;
import java.io.IOException; import org.apache.commons.validator.routines.UrlValidator;
import java.io.InputStream; import org.slf4j.Logger;
import java.io.OutputStream; import org.slf4j.LoggerFactory;
import java.net.URL;
import java.net.URLConnection;
import javax.xml.bind.JAXBContext; import javax.xml.bind.JAXBContext;
import javax.xml.bind.JAXBException; import javax.xml.bind.JAXBException;
import javax.xml.bind.Marshaller; import javax.xml.bind.Marshaller;
import javax.xml.bind.Unmarshaller; import javax.xml.bind.Unmarshaller;
import org.apache.commons.validator.routines.UrlValidator; import java.io.IOException;
import org.slf4j.Logger; import java.io.InputStream;
import org.slf4j.LoggerFactory; import java.io.OutputStream;
import net.ihe.gazelle.tempmodel.org.decor.art.model.Decor; import java.net.http.HttpClient;
import java.net.http.HttpRequest;
import java.net.http.HttpResponse;
...@@ -27,6 +27,11 @@ public final class DecorMarshaller { ...@@ -27,6 +27,11 @@ public final class DecorMarshaller {
private static Logger log = LoggerFactory.getLogger(DecorMarshaller.class); private static Logger log = LoggerFactory.getLogger(DecorMarshaller.class);
private static HttpClient httpClient = HttpClient.newBuilder()
.connectTimeout(java.time.Duration.ofSeconds(10))
.followRedirects(HttpClient.Redirect.ALWAYS)
.build();
private DecorMarshaller() {} private DecorMarshaller() {}
...@@ -65,19 +70,13 @@ public final class DecorMarshaller { ...@@ -65,19 +70,13 @@ public final class DecorMarshaller {
InputStream is = null; InputStream is = null;
try { try {
if (UrlValidator.getInstance().isValid(path)) { if (UrlValidator.getInstance().isValid(path)) {
URL url; is = getInputStreamFromURL(path);
url = new URL(path);
URLConnection urlConnection = url.openConnection();
urlConnection.setConnectTimeout(10000);
urlConnection.setReadTimeout(10000);
is = urlConnection.getInputStream();
else { else {
is = new FileInputStream(path); is = new FileInputStream(path);
return loadDecor(is); return loadDecor(is);
} catch (IOException e) { } catch (IOException | InterruptedException e) {
log.error("Error to load decor from url : " + path, e); log.error("Error to load decor from url : " + path, e);
}finally { }finally {
if (is != null) { if (is != null) {
...@@ -106,5 +105,14 @@ public final class DecorMarshaller { ...@@ -106,5 +105,14 @@ public final class DecorMarshaller {
mar.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true); mar.setProperty(Marshaller.JAXB_FORMATTED_OUTPUT, true);
mar.marshal(decor, os); mar.marshal(decor, os);
private static InputStream getInputStreamFromURL(String url) throws IOException, InterruptedException {
HttpRequest request = HttpRequest.newBuilder()
.GET()
.uri(java.net.URI.create(url))
.build();
HttpResponse<InputStream> response = httpClient.send(request, HttpResponse.BodyHandlers.ofInputStream());
return response.body();
