GitLab
Explore
Primary navigation
Search or go to…
G
Gazelle Objects Checker
Manage
Plan
Issue boards
Code
Merge requests
Repository graph
Compare revisions
Build
Pipeline schedules
Artifacts
Deploy
Package Registry
Model registry
Operate
Environments
Terraform modules
Monitor
Incidents
Service Desk
Analyze
Value stream analytics
Contributor analytics
CI/CD analytics
Repository analytics
Model experiments
Support
GitLab documentation
Compare GitLab plans
Community forum
Provide feedback
Keyboard shortcuts
Show more breadcrumbs
Gazelle
Library
8fcd74d2
8fcd74d2
3 years ago
Achraf Achkari
Downloads
Patches
Fix Generation Scripts
04a44175
1 merge request
!15
Release 3.0.2
Pipeline
#338399
failed
3 years ago
Stage: build
Stage: tests
hl7templates/hl7templates-packager-jar/src/main/resources/assemble-scripts/eHDSIGeneration.sh
+1
-1
1 addition, 1 deletion
...ar/src/main/resources/assemble-scripts/eHDSIGeneration.sh
1 addition
1 deletion
8fcd74d2
@@ -179,7 +179,7 @@ fi;
echo
-e
GREEN
your validator will be generated in:
workspaceDir
folderName
NC
echo
-e
GREEN
workspaceDir
folderName
NC
######## GENERATION COMMAND ########
$JAVA_HOME/bin/java -jar $jarPath -bbr $bbrPath -out "${workspaceDir}/${folderName}" -mvn $mavenPath -serviceName $validator -HL7TEMP_CDACONFFOLDERNAME cdaepsos
$JAVA_HOME
/bin/java
-jar
$jarPath
-bbr
$bbrPath
-out
workspaceDir
folderName
-mvn
$mavenPath
-serviceName
$validator
cdaepsos
#Replacing XSD
#Replacing XSD
This diff is collapsed.
Loading
Save comment
