Commit 3efee039 authored by Achraf Achkari's avatar Achraf Achkari
Update Docs
parent 9460f562
2 merge requests!2Release GOC,!1Release GOC
docs/Improved_Logging_Conception_v2.jpg
93.3 KiB | W: | H:
95.5 KiB | W: | H:
  • 2-up
  • Swipe
  • Onion skin
......@@ -291,11 +291,17 @@ Example with SEQUOIA:
**For logs:**
>Root folder of the provided output path
> Go to the root folder of the provided output path
> `cd /home/mylap/Documents/GOC-OUTPUT/logs/logs-[generation_date_time]`
More details about logs will be provided later.
**Logs are separated as follow:**
- **generated_report.log:** contains synthetic report about the generation process (`Warnings` and `Errors`)
- **detailed_report.log:** contains all the logging information from the generation process (`Infos`, `Warnings`, `Errors`)
- **cmdOutput.log:** contains the Stanrd Output of executed commands during generation (maven command to init project with archetype, generate code from OLC, packaging...)
- **cdeModelsErros.txt:** contains all detected inconsetencies between the provided BBR and pre-defined models used by GOC
![Logs Conception](Improved_Logging_Conception_v2.jpg "LogsConception")
<div id='validateCDA'/>
......@@ -381,4 +387,4 @@ You can find some previous made documentation here _(belong the old GOC, and cou
- Functional description of GOC
- Pepare validator for SEQUOIA
- Use interactif scripts for generation
- New Archetecture used for logging
